Post by d00zah » Fri Mar 31, 2023 4:00 pm
heralded wrote: Fri Mar 31, 2023 3:46 pm Thank you for the tip. Before I brick my drive, is the command now supposed to look like this:
./sdftool rawflash enc --drive=HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO6M2QB3331 --sdf-file=/Users/username/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ slim\ BU40N/sdf.bin -v
If that is in correct, may I have the exact command I should use?
Examples can be found in the 1st post of this topic...
How To Flash Videos and commands:
Mac/linux commands to flash.
- OR -
Flashing firmware on a Mac for LibreDrive
andrewtopher
Post by andrewtopher » Sat Apr 01, 2023 10:39 pm
Ugh tried the suggestions enc and rawflash full
Here are the commands I used....
./makemkvcon f -d '/IOBDServices/D3B8A48E' -f /tmp/sdf.bin rawflash full -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
./makemkvcon f -d '/IOBDServices/D3B8A48E' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Same error as before failing to open discs. I'm about to send this back to Amazon and buy a pre flashed.
Post by Billycar11 » Sun Apr 02, 2023 2:29 pm
andrewtopher wrote: Sat Apr 01, 2023 10:39 pm Ugh tried the suggestions enc and rawflash full
What's the output in the terminal say
andrewtopher
Post by andrewtopher » Mon Apr 03, 2023 3:22 pm
Billycar11 wrote: Sun Apr 02, 2023 2:29 pm
It says completed successfully in terminal.
Post by Billycar11 » Mon Apr 03, 2023 6:49 pm
andrewtopher wrote: Mon Apr 03, 2023 3:22 pm
yeah but like the whole command you put in and other stuff it says
andrewtopher
Post by andrewtopher » Tue Apr 04, 2023 2:07 am
Billycar11 wrote: Mon Apr 03, 2023 6:49 pm
Oh my bad, here you go.
andrewhooper@Andrews-iMac MacOS % ./makemkvcon f -d '/IOBDServices/D3B8A48E' -f /tmp/sdf.bin rawflash full -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Flashing flags = 0x1 : 0 0 0 1 : ---- ---- ---- BOOT
Current Drive ID: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIK04N14G2846
Using USB chipset workaround for Desktop drive handshake
yes
100% Operation finished
Done successfully
Post by Billycar11 » Tue Apr 04, 2023 2:18 am
andrewtopher wrote: Tue Apr 04, 2023 2:07 am
yes
Done successfully
replace full with enc
andrewtopher
Post by andrewtopher » Wed Apr 05, 2023 3:26 am
Billycar11 wrote: Tue Apr 04, 2023 2:18 am
yes
Done successfully
Okay I tried that but it's still giving the libra drive error. Could it be that it's not the right firmware I chose?
Post by Billycar11 » Wed Apr 05, 2023 5:45 am
post the Log cant help if i dont see what happened
Post by dcoke22 » Wed Apr 05, 2023 1:30 pm
It has been a while since I flashed a drive… do you need to power cycle the drive after the flash?
Post by Billycar11 » Wed Apr 05, 2023 10:31 pm
dcoke22 wrote: Wed Apr 05, 2023 1:30 pm It has been a while since I flashed a drive… do you need to power cycle the drive after the flash?
No it will show updated info right away but I do recommend powering it down after a flash
heralded
Post by heralded » Thu Apr 06, 2023 4:05 am
d00zah wrote: Fri Mar 31, 2023 4:00 pm
- OR -
@d00zah - Thank you for the additional info. That's what I needed.
Product: BD-RE BU40N
Revision: 1.03
Serial number: ************
Firmware date: 2118-10-24 19:34  (<<< Maybe 2018-10-24???)
Highest AACS version: 78
Firmware version: 1.03
jt5298
Flashing LG WH16NS40 back to original 1.03 firmware
Post by jt5298 » Thu Apr 06, 2023 5:49 pm
I want to flash my LG WH16NS40 back to the original 1.03 firmware. I flashed it to 1.02MK using the instructions here. It is now LG WH16NS60 1.00 firmware only because I thought the grinding was related to the 1.02MK firmware. Anyway, just want to know if this is possible without messing up my drive. If it will work, is there a download of the 1.03 firmware I can use to do this? If I could please just get a yes or no answer, this will work or not, and not ask why I am wanting to do this.
Thanks.
Re: Flashing LG WH16NS40 back to original 1.03 firmware
Post by Billycar11 » Thu Apr 06, 2023 7:06 pm
jt5298 wrote: Thu Apr 06, 2023 5:49 pm I want to flash my LG WH16NS40 back to the original 1.03 firmware. I flashed it to 1.02MK using the instructions here. It is now LG WH16NS60 1.00 firmware only because I thought the grinding was related to the 1.02MK firmware. Anyway, just want to know if this is possible without messing up my drive. If it will work, is there a download of the 1.03 firmware I can use to do this? If I could please just get a yes or no answer, this will work or not, and not ask why I am wanting to do this.
Thanks.
Yes it's possible
jt5298
Post by jt5298 » Thu Apr 06, 2023 7:36 pm
Yes it's possible
Thank you. Is there a download on this site of the 1.03 firmware I can use? If not, will the 1.03 firmware from the LG website work? or is it encrypted.
