LibreDrive for Pioneer drives
zaqqaz6917
To the best of my knowledge if you file a claim on AliExpress of item not has described they will refund your money. Happened to me with some item, sent them a picture of scam item, immediately got my money back and was told to either keep or throw away the scam item.
CNCisRobot
I will need proof to send them what can I use as I cant find any information even from Pioneer about the particular drive I have. It is like it never existed!zaqqaz6917 wrote: Wed Mar 22, 2023 10:21 pm To the best of my knowledge if you file a claim on AliExpress of item not has described they will refund your money. Happened to me with some item, sent them a picture of scam item, immediately got my money back and was told to either keep or throw away the scam item.
Blackened2687
This drive is an OEM model intended for Japanese Toshiba laptops with UHD support, of course you won't find any information about it, since it's not a retail model. I have sent Mike the dump from exact drive like yours, please be patient.CNCisRobot wrote: Thu Mar 23, 2023 3:08 pm I will need proof to send them what can I use as I cant find any information even from Pioneer about the particular drive I have. It is like it never existed!
Paul Cordingley
Hi,hansolo wrote: Mon Mar 14, 2022 12:49 pm I can confirm Verbatim #43888 is LibreDrive capable external Pioneer drive. I had it on 1.14 firmware (2020-06-15) from the box matching the following entry.Although it does not matter MakeMKV this drive seems to be official 4K UHD BD drive with AACS2 keys for e.g. proper SGX/PowerDVD Ultra usage (don't botherCode: Select all
PIONEER-BD-RW___BDR-UD04-1.14-489CDFD6-8A10-20200615). There are at least two model number variations and #43888 is the official UHD BD drive.
I bought this drive, same model, same firmware etc. however it does not load Blu-rays at all - just makes knocking noises, sometimes spins up, but always ends up just ejecting the disc after a minute. It should just work, right? Would you say it’s faulty? I’ve tried a number of UHD and Blu-ray Discs. It does, however, read the enclosed disc it came with, PDF manuals etc.
hansolo
Enclosed disc is probably just a CD-ROM or maybe a DVD-ROM. So different laser is used to read those older format discs. Your drive may have a faulty blue laser, which is used for BD discs. If you already tried several different discs without success then I think dirty or faulty discs are not the reason. Maybe try to clean one misbehaving BD with a proper microfibre cloth. If that does not help, contact the retailer.
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
computerlove
I am new to this forum. Wanna to know if Pioneer BDR-S13J-X flashed with firmware 1.04 is a LibreDrive.
The Pioneer BDR S13J-X looks like a Japanese market drive.computerlove wrote: Fri Mar 31, 2023 2:19 pm I am new to this forum. Wanna to know if Pioneer BDR-S13J-X flashed with firmware 1.04 is a LibreDrive.![]()
I think the 1.04 firmware is the one Pioneer released to break LibreDrive support. Others have reported their drive doesn't work on 1.04.
computerlove
Thanks. How can I check whethr it is a LibreDrive?dcoke22 wrote: Fri Mar 31, 2023 2:57 pmThe Pioneer BDR S13J-X looks like a Japanese market drive.computerlove wrote: Fri Mar 31, 2023 2:19 pm I am new to this forum. Wanna to know if Pioneer BDR-S13J-X flashed with firmware 1.04 is a LibreDrive.![]()
If you have the drive, MakeMKV will tell you. After MakeMKV launches, on the right hand side there's a bunch of drive, LibreDrive, and disc information. If LibreDrive is supported, in the LibreDrive section it'll say Status: Enabled. Follow the 'doesn't work' link in my previous post to see an example screenshot (although, for that user it was not supported).
Smith
Hello. I am a novice and have not copied 4k discs before, so I don't know if my problem is user error or an unsupported drive.
I just tried and failed copying three 4k discs.
Pioneer BDR-XD08U
firmware BDR-BDS08, version 1.01/ID05, dated 2022-10-11
Pioneer BDR-XD08U
TeddyRaspin
You have to allow internet connection for MakeMKV in order to download latest Hashed Keys
in order to rip UHD content from a protected disk.
Smith
TeddyRaspin wrote: Sun Apr 02, 2023 10:42 am You have to allow internet connection for MakeMKV in order to download latest Hashed Keys
Enabling internet worked, Thank You
richardlansing
I just purchased this drive BDR-S13U from Amazon and it rips 4K flawlessly:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.03
Serial number: BLDL300187UC
Firmware date: 2022-07-26
Highest AACS version: 78
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID43
OS device name: E:
Revision: 1.03
Verbatin
Hello, I just registered on the web.
I have used your program several times already and have never had any problems.
Now I have changed my uhd disk drive and when I wanted to make a backup copy of my uhd movie it gave me the following error:
La clave de volumen de este disco es desconocida. No se puede desencriptar el video
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:121264372
DEBUG: Code 0 at bYpr+4+pfiV](|$GE@ :121273319
DEBUG: Code 0 at Y76FQ!aYzx)1n73J0s#w:121265338
Fallo al realizar el backup
The uhd drive is:
Información de unidad de disco
Nombre del SO del dispositivo: /dev/rdisk4
Perfil actual: BD-ROM
Fabricante: PIONEER
Producto: BD-RW BDR-UD04
Revisión: 1.11
Número de serie: TADL032997WL
Fecha del firmware: 2018-11-28
Marcas de cifrado bus: 1B
Highest AACS version: 77
Drive platform: RS8A10
Firmware version: 1.11
Is it possible patch?
Thanks very much
The uhd drive is:
Fabricante: PIONEER
Revisión: 1.11
Thanks very much
You must allow Internet access for Makemkv. That's it. Go to View Preferences General and check the box.
