Help with HD-DVD to mkv
The Janitor
Post by The Janitor » Sat May 21, 2011 10:45 pm
Just downloaded makemkv to try out.
I am wanting to make all my hddvds into mkvs & store on hdd.
I have tried 2 different movies & they create a mkv file but wont play with MPC-HC.
Am I doing something wrong? I pick the large evo file & check the language I want.
Icetrips
Re: Help with HD-DVD to mkv
Post by Icetrips » Tue May 24, 2011 4:29 pm
You can't just hope Plug&Play.
MPC is GREAT but he use FFDShow and Haali as external output for make MKV being read properly.
MKV also have a plugin to be able to read .mkv format... but it's old school.
If you just downloaded lastest MPC, this could explain why you can't play any MKV.
I recommend you to download CCCP.
http://www.cccp-project.net/
This contains MPC, FFDShow, Haali and more...
This will fix your issue.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
dpstjp
Post by dpstjp » Thu May 26, 2011 1:47 pm
The Janitor wrote:Am I doing something wrong? I pick the large evo file & check the language I want.
Don't pick the large EVO file, the film might be spread across numerous EVOs. When you open MakeMKV you need to use the "Open disc" button (it's the symbol showing a DVD on the left and an arrow to a hard drive) and let the programme determine what it's going to save.
Are you aware about the Pulldown issue using MakeMKV on HDDVDs? Do a search on this forum for it.
