The Maltese Falcon: 4K UHD
rkhollister
Re: The Maltese Falcon: 4K UHD
Just tried the US disc and it is now working
Still not working for me.
I think there is a difference between the European release (which I have) and the US version.
htpc_rookie
Just tried this disc with no success and submitted a dump file this morning,
MKB20_v77_The_Maltese_Falcon_B6E4.tgz
Working now for me.
Thanks all and whoever is in charge of updating the keys.
I received my copy of the U.S. version of The Maltese Falcon yesterday, but am having the same issue with the volume key. Are these volume keys unique to each member? I’ve only had the issue two or three times. By the way, I sent the dump file to the wrong address yesterday but to the correct address today. Thanks.
The volume keys are unique to a group of disks. Usually, that means they'll be the same across disks produced for a given country, but sometimes not.
Matching disks will come up with the same "hex digits" at the end of the file name, as in all of them created with "_ABCD" in the name will be the same, but "AEF3" will be different. That's why it's best if people post the name of the file being sent to svq@makemkv.com in their post here.
Thanks for your quick reply.
I just read the following post: viewtopic.php?f=12&t=24711
For your information, I received the first message, but not the second message, which is the reason I asked my question about volume keys. However, I do not understand what you mean by the "file name." I know the name of the film, but don't know where to look for the file name when I can't rip the disk and save the file. Are you referring to the name of the dump file? Thanks.
Yes, the name of the dump file. As in the example from that message:
Seeing the second message is not usual... but it happens sometimes. It's when your system isn't getting the updates. A lot of people disable that for security reasons- automatic downloads are an issue for a lot of people. Trusting your antivirus programs is important.
The "_ABCD" is a checksum, calculated based on the file contents, so it changes when the encryption key changes. If you see where someone else has submitted the same checksum file as you have, there's less need to submit YOUR copy, but it doesn't HURT.Saved AACS dump file as C:\Users\xxxxxxxxx/.MakeMKV/New_UHD_Title_ABCD.tgz
MakeMKV failed to load this U.S. disc. Just emailed the dump file:
MKB20_v77_The_Maltese_Falcon_B8FE.tgz
Bill
So, what are we watching tonight?
Here's the missing link.
file:///Users/xxxxxxxx/Library/MakeMKV/MKB20_v77_The_Maltese_Falcon_B8FE.tgz
When I tried to rip the disk again today, I received the following familiar answer:
Saved AACS dump file as /Users/xxxxxxxx/Library/MakeMKV/MKB20_v77_The_Maltese_Falcon_B8FE.tgz
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:121264372
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:213131341
Usually, the volume-key problem is resolved within a couple of days. I am curious to learn why the problem still persists. Thanks.
Just tried again, and still unable to convert the disc.
(Sorry, too "new" to PM.)
Bill
