Unable to backup Plane or Top Gun UHD
Geneo
Post by Geneo » Wed Mar 29, 2023 4:03 pm
Makemkv has been working great up to this point. Both of these titles give an error at the end of the backup process and files.
WH16NS60 is at firmware v1.3
Saving 1 titles into directory /../MKV/Top Gun- Maverick
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '32947568640'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '32947568640'
DEBUG: Code 3221225488 at %uGJTuF,((P}m#0s#v:213131502
DEBUG: Code 101000192 at %uGJTuF,((P}m#0s#v:213131502
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:29395471
DEBUG: Code 0 at zbL_5>@rt`]2L>~L$^Xa:29394068
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:213131157
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:121262647
DEBUG: Code 16087680 at ;A,PZPR7U;07xNLh*7.1:121261773
DEBUG: Code 0 at *M=d>ww icjnMH% jWIDk:213137068
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29394022
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29404878
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29405384
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29403383
DEBUG: Code 0 at Q\VD'h?s=_=Pa=2Y*t2=:213141208
DEBUG: Code 0 at [y`X9mT%RaeY;:Ul:213132537
DEBUG: Code 0 at =5jyb*#Ovz{)&tSyL:121264464
DEBUG: Code 0 at =5jyb*#Ovz{)&tSyL:121263912
DEBUG: Code 0 at =5jyb*#Ovz{)&tSyL:213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 8 to file  /../MKV/Top Gun- Maverick/Top Gun- Mavericke09.mkv
0 titles saved, 1 failed
Geneo
Re: Unable to backup Plane or Top Gun UHD
Post by Geneo » Wed Mar 29, 2023 6:00 pm
I was able to fix this issue with Plane by simply changing the: View -> Preferences -> 'Video' tab -> Minimum title length (seconds) from 120 seconds to 9 seconds. I do not know why this works. Everything else is the same and I have been using these same settings for more than a year. Not sure what was missed at 120 seconds and less title length that would prevent the disc from being backed up. Still getting errors with Top Gun - Maverick.
Geneo
Post by Geneo » Thu Mar 30, 2023 7:41 pm
Well, tried to downgrade the firmware and now the drive no longer reads UHD discs. Reads BluRay fine. Any recomendations?
Post by dcoke22 » Thu Mar 30, 2023 9:42 pm
As always, the Ultimate UHD Drives Flashing Guide has the list recommended firmware for the recommended drives.
As a side note, once you get your drive on the right firmware, it is best to leave the firmware alone.
Post by Billycar11 » Thu Mar 30, 2023 11:59 pm
Sounds like your drive is just bad those WH16/WH14xx and Asus BW drives are bad news.
Try shutting the computer down for a few and flip the PSU switch off and unplug the drive in innan external powered case.
But if it's new just return it and get a BU40N or bp50/60 or a pioneer from the list
Geneo
Post by Geneo » Mon May 15, 2023 9:48 pm
Eventually I had to send the disc back and got another, this one worked,
Thanks all
