BRUHDPU3 Tray does not open
Joe6801
Post by Joe6801 »
When I press the button to open, MKV shows image of it being opened and closed when pressed again but physically it does not. New drive, questionable process to downgrade, as an online video did not reference an error I received when following it. But seems I may have done something right?
Firmware version: 1.05
SDFtool Flasher read info: dump_user_BUFFALO_Optical_Drive_1.05_212005061331_MO8********
Re: BRUHDPU3 Tray does not open
Joe6801 wrote:
Tue Mar 28, 2023 8:47 pm
You flashed it wrong there is no 1.05 for buffalo what did you flash it to
Anyway unplug it asap so you don't burn it out
Do recovery to bu40n 1.03mk
Joe6801
Post by Joe6801 »
As the BH14NS40_N1.00-A4_patched tool encountered an error while trying to launch, used SDFtool to FW to BH14NS50-1.03, that seemed to work as MKV showed a favorable (I assume) status: patched (microcode access re-enabled). Since then, have recovered, various FWs as I cannot write anymore due to error code "0xff05c103". A brick now? Current status:
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.00
Serial number: MO8-----
Firmware date: 2117-04-25 17:56
Firmware version: 1.00
_____
Read with SDFtool: dump_full_BUFFALO_Optical_Drive_1.00_211704251756_MO********
______
Thinking bricked.
Joe6801 wrote:
Wed Mar 29, 2023 10:58 pm
OS device name: E:
Revision: 1.00
_____
______
Thinking bricked.
OMG!!??!! You really should have read the guide!! Why on earth would you flash a slim external drive with desktop drive firmware??
The only chance of recovery is using SDFtool. I assume you have downloaded all of the firmware packs. Follow the steps below:
1. Select your drive
2. Select RECOVERY option
3. In the popup, select the incorrect firmware that you already flashed to the drive
4. Now, in the firmware dropdown box, select BU40N 1.03-MK firmware
5. Press START button
The progress bar will fill up to 100% pretty quickly but do not touch anything until it says it has completed and is "Ready..." The entire process should take around 40 seconds.
Please report back and let us know how you went.
Man- you have a slim drive and you flashed firmwares for full size drives. You need to slow down and flash a slim drive firmware using the recovery option, e.g. BU40N 1.03. Read the instructions !
Joe6801
Post by Joe6801 »
MartyMcNuts wrote:
Wed Mar 29, 2023 11:32 pm
OS device name: E:
Revision: 1.00
_____
______
Thinking bricked.
My apologizes. I knew I should not have done desktop to slim and vice versa. But as a super noob, I have no idea what FW is slim or desktop just by it's name. This is where I think my major confusion was when deciding what was appropriate for my BRUHDPU3 . However, you instruction have seems to have returned my drive to OEM as I can open my tray now. Oh my god! You have no idea how this has made my day so far. Was going to return the drive and give up. I have not proceeded with anything beyond you're instructions. Current status:
OS device name: E:
Revision: 1.03
Serial number: MO8M9F83807
Highest AACS version: 60
Firmware version: 1.03
Joe6801
Post by Joe6801 »
Coopervid wrote:
Wed Mar 29, 2023 11:34 pm
I read the instructions but was lost here:
"If your drive has one of these firmwares, and there is no MK version of the same firmware/drive model or higher number, you will have to sidegrade to Asus 3.10MK (for compatible ASUS 5.25 drives ONLY) or (LG WH16NS60 1.02MK for compatible LG 5.25) or (BU40N 1.03MK LG Slim drives ONLY) respectively. "
Being a Buffalo brand, was lost. Should I have done I Asus or LG?
Joe6801
Post by Joe6801 »
OS device name: E:
Revision: 1.00
_____
______
Thinking bricked.
I just popped in a random UHD disc. I think you helped me fix my whole confusion as rip options appear. I bought this drive to have it in case I wanted to rip my collection (not hardcore on it or anything, but always want the option). My original desperation turned to failure and has been quickly converted to success. You my many thanks. I really appreciate your time and this community. I will purchase the full version of MKV as my small contribution to this pursuit in ultimate personal media ownership.
OS device name: E:
Revision: 1.00
_____
______
Thinking bricked.
Man who told you to flash bh14ns40 I just said flash to bu40n 1.03 mk.
As Marty said choose recovery select the wrong fw you flashed then BU40N 1.03mk the longer you leave it like this the more chance of it getting messed up
Joe6801
Post by Joe6801 »
Billycar11 wrote:
Thu Mar 30, 2023 12:24 am
OS device name: E:
Revision: 1.00
_____
______
Thinking bricked.
It has been done. All is well, thanks.
