wrong display size (widescreen)
stevenm56
#1 Post by stevenm56 » Tue Mar 28, 2023 5:30 pm
I just used Makemkv to rip a copy of I Robot which polay in a dvd player as widescreen. However, the disc is labelled full screen and the Ripped mkv file is standard, a square. What did I do wrong. TIA
Re: wrong display size (widescreen)
#2 Post by dcoke22 » Tue Mar 28, 2023 6:19 pm
Blu-ray.com has two entries for I, Robot (2004) on DVD. A full-screen version and a wide-screen version.
So, if you have the full-screen version then I would expect MakeMKV's output to be in full-screen (aspect ratio of 1.33:1 if you want to think about it that way).
If that same full-screen DVD shows up as 'widescreen' on your TV when you play the DVD in a DVD player, it is possible your TV is set to stretch full-screen content to fit the width of your screen.
