[SOLVED] Seems makemkv don't see the KEYDB.cfg file
mirto
#1 Post by mirto » Mon Mar 27, 2023 10:04 am
Hi all,
I have Debian testing with makemkv 1.17.3 installed using the instructions at
viewtopic.php?f=3&t=224
I have the KEYDB.cfg file installed at ~/.config/aacs/
When I try to open a BD iso image it fails saying
MakeMKV v1.17.3 linux(x64-release) inizializzato
Il programma non ha trovato alcun lettore ottico.
Uso modalità di accesso diretto
Tabella del contenuto hash caricata. Sarà verificata l'integrità dei files M2TS.
Il file di scaricamento memoria AACS è stato salvato come /home/XXXXXXX/.MakeMKV/MKB_v43_Now_You_See_Me_E1A0.tgz
La chiave del volume di questo disco è sconosciuta. Il video non può essere decriptato.
Impossibile aprire il disco
If I open the same iso image with VLC it works perfectly.
Seems that makemkv cannot reach the KEYDB.cfg file.
What can I do?
Re: Seems makemkv don't see the KEYDB.cfg file
#2 Post by Woodstock » Mon Mar 27, 2023 1:07 pm
Submit the file MKB_v43_Now_You_See_Me_E1A0.tgz to svc@makemkv.com for analysis. And make sure your copy of the program can access internet to pick up updates.
keydb.cfg isn't mentioned in the MakeMKV online documentation, going back to version 1.01. I cannot see any documentation saying it is used. I remember trying it a few times, but it did not seem to do anything.
mirto
#3 Post by mirto » Tue Mar 28, 2023 7:23 am
Ok here is the file.
I added another file of another BD disk that had the same error.
How can I test if makemkv can reach Internet?
MKB_v62_Resident_Evil-_The_Final_Chapter_2602.tgz
(153.58 KiB) Downloaded 1513 times
(128.09 KiB) Downloaded 1576 times
#4 Post by Woodstock » Tue Mar 28, 2023 1:12 pm
The log will tell whether or not MakeMKV can reach the internet. If your logging settings are set high enough, that is. The default is rather low, in my opinion, but it is easily switched.
In program settings, General, "Enable Internet access" checked sets that up. It's been checked so long on my copies that I can't remember if it is automatic or not. :)
mirto
#5 Post by mirto » Tue Mar 28, 2023 5:36 pm
Well, it seems that internet access is already enabled.
Have i to select the debug log option and try again to give more information?
#6 Post by Woodstock » Tue Mar 28, 2023 6:26 pm
Yes, add a check mark for debug information being recorded. Your log window will show more stuff, and the log FILE for the application will grow even more.
You should be able to tell from the log file if it is able to download the disc decryption data, or if it had an error doing so.
mirto
#7 Post by mirto » Tue Mar 28, 2023 7:06 pm
Here are the log window and the generated file.
But I don't see anything I can understand.
What can I try?
(128.18 KiB) Downloaded 1569 times
#8 Post by dcoke22 » Tue Mar 28, 2023 11:12 pm
I can't read Italian, but my phone can do a reasonable job of translating.
In the Fixing Volume Key is Unknown post, it says you would see 'Automatic HK downloading is disabled or failed.' if there was a problem. I do not see that message in your log so it would seem that things are working but no key exists for disc.
As Woodstock suggested, please email that file to svq@makemkv.com
mirto
#9 Post by mirto » Wed Mar 29, 2023 7:24 am
Well, seems a dns problem.
From Italy I wasn't able to obtain the hkdata.fairuse.org ip address using Google or Cloudflare
mirto@bianco500:~$ nslookup hkdata.fairuse.org 8.8.8.8
Server:         8.8.8.8
Address:        8.8.8.8#53
** server can't find hkdata.fairuse.org: NXDOMAIN
mirto@bianco500:~$ nslookup hkdata.fairuse.org 8.8.4.4
Server:         8.8.4.4
Address:        8.8.4.4#53
mirto@bianco500:~$ nslookup hkdata.fairuse.org 1.1.1.1
Server:         1.1.1.1
Address:        1.1.1.1#53
But the post you cited says:
hkdata.fairuse.org is no longer used!
BTW adding the address to the /etc/hosts file not work: the address is unreachable
mirto@debiantesting:~$ tracepath hkdata.fairuse.org
 1?: [LOCALHOST]                      pmtu 1500
 1:  _gateway                                              0.152ms
 1:  _gateway                                              0.102ms
 2:  192.168.68.1                                          1.244ms
 3:  myfastgate.nexxt                                      3.536ms
 4:  10.1.131.180                                         16.816ms
 5:  10.1.133.161                                         11.355ms
 6:  10.1.133.150                                         15.623ms
 7:  10.1.133.158                                         13.391ms
 8:  10.1.155.17                                          11.343ms
 9:  10.254.20.9                                          13.596ms asymm 11
10:  93-57-68-102.ip163.fastwebnet.it                     12.538ms
11:  93-57-68-141.ip163.fastwebnet.it                     13.458ms asymm 10
12:  hurricaneelectric.rom.namex.it                       20.702ms asymm 11
13:  no reply
14:  100ge0-30.core2.cph1.he.net                          39.764ms asymm 11
15:  100ge0-76.core3.sto1.he.net                         107.029ms asymm 12
16:  inetcom-as35598.e0-51.switch1.sto2.he.net            81.871ms asymm 14
17:  100.105.100.134                                      66.409ms asymm 12
18:  no reply
19:  193.233.16.35                                        69.034ms asymm 14
20:  193.233.16.35                                        71.814ms pmtu 1476
20:  193.233.16.35                                        68.949ms asymm 14
21:  no reply
22:  no reply
23:  no reply
24:  no reply
25:  no reply
26:  no reply
27:  no reply
28:  no reply
29:  no reply
30:  no reply
     Too many hops: pmtu 1476
     Resume: pmtu 1476
mirto@debiantesting:~$ cat /etc/hosts
127.0.0.1       localhost
127.0.1.1       debiantesting.net       debiantesting
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
91.224.23.225 hkdata.fairuse.org
How can I obtain a usable IP?
If the file at http://fvonline-db.bplaced.net/ is compatible with makemkv, where I can put this file to override the download problem?
P.S. sorry for the Italian language
The window log was
MakeMKV v1.17.3 linux(x64-release) started
Debug logging enabled, log will be saved as /home/mirto/MakeMKV_log.txt
The program can't find any usable optical drives.
DEBUG: Code 16842752 at '5BE>tA"Gf|~89y(o3:121264027
Saved AACS dump file as /home/mirto/.MakeMKV/MKB_v43_Now_You_See_Me_E1A0.tgz
DEBUG: Code 0 at m8o?n>P"p@YJs!ps:121264372
DEBUG: Code 0 at m8o?n>P"p@YJs!ps:213131341
#10 Post by dcoke22 » Wed Mar 29, 2023 1:27 pm
Recently, others have mentioned needing to use a VPN with an exit point in Asia.
DNS Issues in the US for hkdata.fairuse.org
That post does mention getting the 'Automatic HK downloading is disabled or failed' message, which I don't think you're getting.
Personally, I haven't needed to decrypt a UHD in a while, so I haven't run into this problem.
mirto
#11 Post by mirto » Sat Apr 08, 2023 4:00 pm
[SOLVED]
I've found where to put the KEYDB.cfg file: it is where makemkv writes the log
After issuing these commands
cd ~/.config/aacs
cp KEYDB.cfg ~/.MakeMKV/
and restartting makemkv I was able to open the BD
File 00001.mpls was added as title #0
File 00019.mpls was added as title #1
Title #00015.mpls(1) has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00017.m2ts was added as title #2
Title #00013.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #3
File 00011.m2ts was added as title #4
Title #00010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #5
Title #00008.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #6
Title #00004.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00003.m2ts was added as title #7
File 00002.m2ts was added as title #8
File 00001.m2ts was added as title #9
File 00000.m2ts was added as title #10
Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
NoHacksJustParker
Re: [SOLVED] Seems makemkv don't see the KEYDB.cfg file
#12 Post by NoHacksJustParker » Wed Mar 06, 2024 6:23 pm
if possible could someone explain how to do this but on windows because I'm having some issues with getting makemkv recognizing it as well
hulahoo
#13 Post by hulahoo » Thu Mar 14, 2024 6:22 pm
On MacOS, copy KEYDB.cfg (case-sensitive) to ~/Library/MakeMKV and restart MakeMKV.
DQduck
#14 Post by DQduck » Fri Dec 19, 2025 8:13 pm
As this was the top search result for me I'd like to amend two things:
1) On windows the file needs to be copied into `%userprofile%/.MakeMKV`
2) Seeing things like
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom4'
in the log does NOT mean that MakeMKV was ignoring the KEYDB.cfg file. If it returns to the main screen automatically right after only then it failed. MakeMKV apparently at first tries to read the keys from the disk and only then fails back to using the KEYDB.cfg file. So ignore these log lines and WAIT. Don't get impatient and hit abort once they're logged.
