quietvoid wrote: ↑Sun Mar 26, 2023 4:54 pm
I don't know, never seen the EL for that.
Remember that problem I contacted you about that I was seeing for the NF DV8 files?
Same problem again, NF title again, but different NF title.
I'll break it down and show screenshots of what I'm talking about - sample files attached
The DV8 file shows artifacts - looks just like RPU misalignment artifacts to me (look at his face down the middle and the red square overlaying it) - it shows this way both on Windows with the DV extension installed, and on my DV capable Android TV - so it's not just a Windows thing
Now, if I demux the HEVC file in Dovi_Tool - that should leave me with a HDR10 BL only (and the separate EL) - which it seemingly does, and mediainfo seems to report the same - but look what happens when viewing this 'supposed HDR10 only' file - the same artifacts show up on playback - again this is both on Windows and Android TV that the HDR10 file shows what appear to be RPU artifacts when there should be no RPU info in the file at all
Now, if I playback either the DV8 or supposed only HDR10 file, in a non-DV capable player like VLC - look - no RPU artifacts at all!
Something has to be going on here, just like I noticed with the Community files (also saw this on a NF movie as mentioned) - and again - it's ONLY NF TITLES I see this bug on :/
Here are the files - 'DVBad.m4v' is the DV8 file as you get it - the '10Bad.m4v' file is the supposed HDR10 only hevc after run through Dovi_tool that should have no RPU info in it, but appears to still do
https://mega.nz/file/8L5l3AaZ#Q7NxdKLmJ ... bE-fiBbBVA
