Let's say I'm ripping a Bluray disc that contains a couple of different episodes (ie. a TV show).
The files that get created are named "title00.mkv, title01.mkv, title02.mkv".
Is there any (easy?) way to determine what the titles should be?
How can I determine the title names for episode discs?
Re: How can I determine the title names for episode discs?
Usually the disc box gives the names of the episodes on the discs.
There is one way you might be able to do it but I haven't tried this personally, is name the folder after the TV show then use The Renamer on the folder and it should hopefully auto-rename the files in the folder.
+1 Woodstock's post.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK x2
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Linux / Windows 10
LG GGC-H20L 1.03
