Multiple Errors Attempting to DVD into MKV Files
4ener
Post by 4ener »
I need some help with one, I've managed to do this with several BlueRay disks with with no problems at all. But with normal disks in this case no success at all. Below what came up after my last try, hopefully someone somewhere can tell what's going on... software or hardware it's got to one or the other or both.
MakeMKV v1.17.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\blair/MakeMKV_log.txt
Backing up disc into folder "K://backup/DEADWOOD_S1D1.iso"
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.05 KLZK8HG4111' at offset '4049797120'
DEBUG: Code 0 at p&TMee"(XeSmqBY;(Jd}:121266097
Backup failed
DEBUG: Code 4294967294 at E9c-$0{W(c6Jm.J'p|na:213133250
DEBUG: Code 14 at E9c-$0{W(c6Jm.J'p|na:121265062
DEBUG: Code 0 at E9c-$0{W(c6Jm.J'p|na:29394689
DEBUG: Code 0 at d\C_XM&wlJ8e7y:29397104
Cells 9-9 were removed from title end
Title #3 was added (8 cell(s), 1:01:29)
Title #4 was added (8 cell(s), 0:55:47)
Title #12 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory K:/
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '1674795008'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '1674795008'
DEBUG: Code 3221225488 at %uGJTuF,((P}m#0s#v:213131502
DEBUG: Code 101000192 at %uGJTuF,((P}m#0s#v:213131502
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:29395471
DEBUG: Code 0 at %UdSDL"Iejhui(`P~;&:29393562
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:213131157
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:121262647
DEBUG: Code 817771 at ;A,PZPR7U;07xNLh*7.1:121261773
DEBUG: Code 0 at ZxpmVf&p,a\GzmEpFK%A(/:121263751
DEBUG: Code 0 at *M=d>ww icjnMH% jWIDk:213137068
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29394022
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29404878
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29405384
DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29403383
DEBUG: Code 1 at ^('RV<7SQ.@%aWa<:121263567
DEBUG: Code 0 at ^('RV<7SQ.@%aWa<:213133020
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:121261773
Failed to save title 1 to file K://title_t01.mkv
Encountered 4 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
1 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '1674795008'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1674795008'
DEBUG: Code 3221225628 at %uGJTuF,((P}m#0s#v:213131502
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '1674795008'
DEBUG: Code 100941314 at %uGJTuF,((P}m#0s#v:213131502
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '1674795008'
DEBUG: Code 100860416 at %uGJTuF,((P}m#0s#v:213131502
Failed to save title 1 to file K://D1_t01.mkv
Encountered 8 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Current profile: DVD-ROM
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLZK8HG4111
Highest AACS version: 21
Hardware support: Yes
Firmware support: No
Firmware version: 1.05
Disc Information
Label: DEADWOOD_S1D1
Timestamp: 2009-11-05 14:49:36
Data capacity: 4.30 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 1 (PTP)
Re: Multiple Errors Attempting to DVD into MKV Files
Read errors like that almost always mean the disc is dirty or damaged. Try gently cleaning the disc.
If you're experiencing rip errors, please read here first!
