quietvoid
Post by quietvoid » Wed Mar 15, 2023 8:20 pm
jorgen wrote: Wed Mar 15, 2023 6:25 pm Question is if keeping a mkv backup is future proof. The bug I understand is converting the other way, from BDMV structure with TSMuxer to mkv again?
Thanks in advance.
Yes the bug is to go back BDMV -> MKV.
Otherwise using TSMuxer should probably be fine for playback.
rosavanwinkle
Post by rosavanwinkle » Fri Mar 17, 2023 4:45 am
So a quick question i want to ask,i use a shield,and i mostly use workflow 4-1-1
this works perfectly fine for me, i use the 1.7.7_MKV script and changed a few things
i for example convert my audio to DDP 5.1 1536kb/s
which is the way for me.
but is there a way i can remove the main dolby truehd with atmos track?
it keeps the new one and the original one in the file as you can see below, anything i can change in my settings to remove the original one? thanks!
EDIT: it also doesnt seem to keep all the subtitle tracks that are in the original file for some reason...
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Fri Mar 17, 2023 12:05 pm
rosavanwinkle wrote: Fri Mar 17, 2023 4:45 am So a quick question i want to ask,i use a shield,and i mostly use workflow 4-1-1
yes, for BD input the audio and subtitles selection is limited. I suggest you disable the muxing(line 21) and then you will be able to select all the tracks you want.
I might look into it for the next version...
jorgen wrote: Wed Mar 15, 2023 6:25 pm The process I'm interested in is this:
- Rip retail UHD disc to mkv and store on NAS
- Keep mkv file on NAS
- Create temporary BDMV structure with TSMuxer from mkv to watch movie on Oppo player (with best DV support)
- Delete BDMV files
yes you can do that with my script (4-3). If you disable the muxing (line 21), tsmuxer will be launched at the end of the workflow. Then select BDMV folder and mux.
Hellboy.
Post by Hellboy. » Mon Mar 20, 2023 8:02 pm
RESET_9999 wrote: Fri Mar 17, 2023 12:05 pm
I was reading your "Dolby Vision Stuff". Thanks for all the information. I have some question.
1-For Blu-ray folder what you recommend, the Sony x700 or x800m2?
2-The x700m2 work the same as the x700?
Post by RESET_9999 » Mon Mar 20, 2023 9:56 pm
both works the same so , i guess the cheaper one is better (x700)
Hellboy. wrote: Mon Mar 20, 2023 8:02 pm 2-The x800m2 work the same as the x700?
They mostly work the same but the x800m2 is better because of the 5ghz wifi and it has fewer bugs.
Hellboy.
Post by Hellboy. » Mon Mar 20, 2023 11:19 pm
RESET_9999 wrote: Mon Mar 20, 2023 9:56 pm
Sorry, in the second question i mean x700m (and i write x700m2).
I want to know if the newer x700m work the same as the old x700?
https://www.amazon.com/Sony-Theater-Str ... B08ZFYVS9T
Post by RESET_9999 » Tue Mar 21, 2023 12:26 am
i dont know. looks the same as the x700
johnjon94
Post by johnjon94 » Thu Mar 23, 2023 8:59 pm
RESET_9999 wrote: Tue Mar 21, 2023 12:26 am i dont know. looks the same as the x700
Currently the option to overwrite L2 trim passes doesn't work directly with just an RPU or XML file. It processes the file, generates the new RPU, but then deletes the new RPU immediately after it was generated. Is there any chance you could fix this?
Edit: I take that back, after changing the setting to set keep_rpu=YES it began to save the new RPU file.
staknhalo
Post by staknhalo » Sat Mar 25, 2023 10:43 pm
Anyone here look at the Star Trek The Next Generation movies that recently are out in 4k BR DV FEL?
I've never seen so much video data in a FEL stream before (from just doing the put it in an mkv container and playback to see if FEL or if all green=MEL thing)!
Normally you see a few multi-colored motion artifacts and that's it. Here, almost the entire image is produced/viewable.
Anything special/unique about these, or I just never came across it/noticed it on any other titles before?
quietvoid
Post by quietvoid » Sat Mar 25, 2023 11:01 pm
staknhalo wrote: Sat Mar 25, 2023 10:43 pm Anyone here look at the Star Trek The Next Generation movies that recently are out in 4k BR DV FEL?
From RESET_9999's plots, the FEL probably restores 2000/4000 nits brightness.
I have not checked, but I could if you have a sample.
staknhalo
Post by staknhalo » Sat Mar 25, 2023 11:32 pm
quietvoid wrote: Sat Mar 25, 2023 11:01 pm
https://mega.nz/file/JLoSkB7S#ph9fGLlLF ... p5nSchf3_E
quietvoid
Post by quietvoid » Sat Mar 25, 2023 11:49 pm
Ah I meant with the base layer too.
Does look like it would increase brightness, though. Hard to know without the full BL+EL+RPU.
staknhalo
Post by staknhalo » Sun Mar 26, 2023 12:46 am
quietvoid wrote: Sat Mar 25, 2023 11:49 pm
https://mega.nz/file/RaRylCZS#2VyRTsOm3 ... sqD6cGfpRc
had to make clip shorter, too much to upload for my crap internet lol
quietvoid
Post by quietvoid » Sun Mar 26, 2023 2:18 am
staknhalo wrote: Sun Mar 26, 2023 12:46 am https://mega.nz/file/RaRylCZS#2VyRTsOm3 ... sqD6cGfpRc
That sample has little frames where brightness is increased, but a lot of near black is darkened.
It seems to improve near black contrast and brighten some specular highlights from 1000 nits to 1700 nits here.
https://slow.pics/c/o2cjQYZi
You can see the bottom left is brighter and the near black deeper.
It probably also improves on the compression artifacts a bit.
staknhalo
Post by staknhalo » Sun Mar 26, 2023 4:38 pm
quietvoid wrote: Sun Mar 26, 2023 2:18 amIt probably also improves on the compression artifacts a bit.
Ahhhh I didn't even think of that - does Total Recall or whatever that infamous one is - does the FEL look the same on that too where you can pretty much make out the entire image in the FEL alone?
