LibreDrive for Pioneer drives
zaqqaz6917
#526 Post by zaqqaz6917 » Wed Mar 22, 2023 10:21 pm
To the best of my knowledge if you file a claim on AliExpress of item not has described they will refund your money. Happened to me with some item, sent them a picture of scam item, immediately got my money back and was told to either keep or throw away the scam item.
CNCisRobot
#527 Post by CNCisRobot » Thu Mar 23, 2023 3:08 pm
zaqqaz6917 wrote: Wed Mar 22, 2023 10:21 pm To the best of my knowledge if you file a claim on AliExpress of item not has described they will refund your money. Happened to me with some item, sent them a picture of scam item, immediately got my money back and was told to either keep or throw away the scam item.
I will need proof to send them what can I use as I cant find any information even from Pioneer about the particular drive I have. It is like it never existed!
Blackened2687
#528 Post by Blackened2687 » Thu Mar 23, 2023 4:43 pm
CNCisRobot wrote: Thu Mar 23, 2023 3:08 pm I will need proof to send them what can I use as I cant find any information even from Pioneer about the particular drive I have. It is like it never existed!
This drive is an OEM model intended for Japanese Toshiba laptops with UHD support, of course you won't find any information about it, since it's not a retail model. I have sent Mike the dump from exact drive like yours, please be patient.
Paul Cordingley
#529 Post by Paul Cordingley » Mon Mar 27, 2023 7:32 am
hansolo wrote: Mon Mar 14, 2022 12:49 pm I can confirm Verbatim #43888 is LibreDrive capable external Pioneer drive. I had it on 1.14 firmware (2020-06-15) from the box matching the following entry.
PIONEER-BD-RW___BDR-UD04-1.14-489CDFD6-8A10-20200615
Although it does not matter MakeMKV this drive seems to be official 4K UHD BD drive with AACS2 keys for e.g. proper SGX/PowerDVD Ultra usage (don't bother :D). There are at least two model number variations and #43888 is the official UHD BD drive.
I bought this drive, same model, same firmware etc. however it does not load Blu-rays at all - just makes knocking noises, sometimes spins up, but always ends up just ejecting the disc after a minute. It should just work, right? Would you say it’s faulty? I’ve tried a number of UHD and Blu-ray Discs. It does, however, read the enclosed disc it came with, PDF manuals etc.
hansolo
#530 Post by hansolo » Wed Mar 29, 2023 11:22 am
Enclosed disc is probably just a CD-ROM or maybe a DVD-ROM. So different laser is used to read those older format discs. Your drive may have a faulty blue laser, which is used for BD discs. If you already tried several different discs without success then I think dirty or faulty discs are not the reason. Maybe try to clean one misbehaving BD with a proper microfibre cloth. If that does not help, contact the retailer.
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
computerlove
#531 Post by computerlove » Fri Mar 31, 2023 2:19 pm
I am new to this forum. Wanna to know if Pioneer BDR-S13J-X flashed with firmware 1.04 is a LibreDrive. :?:
#532 Post by dcoke22 » Fri Mar 31, 2023 2:57 pm
computerlove wrote: Fri Mar 31, 2023 2:19 pm I am new to this forum. Wanna to know if Pioneer BDR-S13J-X flashed with firmware 1.04 is a LibreDrive. :?:
The Pioneer BDR S13J-X looks like a Japanese market drive.
I think the 1.04 firmware is the one Pioneer released to break LibreDrive support. Others have reported their drive doesn't work on 1.04.
computerlove
#533 Post by computerlove » Fri Mar 31, 2023 3:16 pm
dcoke22 wrote: Fri Mar 31, 2023 2:57 pm
Thanks. How can I check whethr it is a LibreDrive?
#534 Post by dcoke22 » Fri Mar 31, 2023 9:48 pm
computerlove wrote: Fri Mar 31, 2023 3:16 pm Thanks. How can I check whethr it is a LibreDrive?
If you have the drive, MakeMKV will tell you. After MakeMKV launches, on the right hand side there's a bunch of drive, LibreDrive, and disc information. If LibreDrive is supported, in the LibreDrive section it'll say Status: Enabled. Follow the 'doesn't work' link in my previous post to see an example screenshot (although, for that user it was not supported).
Smith
#535 Post by Smith » Sun Apr 02, 2023 4:25 am
Hello. I am a novice and have not copied 4k discs before, so I don't know if my problem is user error or an unsupported drive.
I just tried and failed copying three 4k discs.
Pioneer BDR-XD08U
firmware BDR-BDS08, version 1.01/ID05, dated 2022-10-11
MakeMKV screenshot.jpg (152.44 KiB) Viewed 24290 times
TeddyRaspin
#536 Post by TeddyRaspin » Sun Apr 02, 2023 10:42 am
You have to allow internet connection for MakeMKV in order to download latest Hashed Keys
in order to rip UHD content from a protected disk.
Smith
#537 Post by Smith » Mon Apr 03, 2023 4:44 am
TeddyRaspin wrote: Sun Apr 02, 2023 10:42 am You have to allow internet connection for MakeMKV in order to download latest Hashed Keys
Enabling internet worked, Thank You
richardlansing
#538 Post by richardlansing » Wed Apr 05, 2023 11:08 pm
I just purchased this drive BDR-S13U from Amazon and it rips 4K flawlessly:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.03
Serial number: BLDL300187UC
Firmware date: 2022-07-26
Highest AACS version: 78
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID43
Verbatin
#539 Post by Verbatin » Fri Apr 07, 2023 4:27 pm
Hello, I just registered on the web.
I have used your program several times already and have never had any problems.
Now I have changed my uhd disk drive and when I wanted to make a backup copy of my uhd movie it gave me the following error:
La clave de volumen de este disco es desconocida. No se puede desencriptar el video
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:121264372
DEBUG: Code 0 at bYpr+4+pfiV](|$GE@ :121273319
DEBUG: Code 0 at Y76FQ!aYzx)1n73J0s#w:121265338
Fallo al realizar el backup
The uhd drive is:
Información de unidad de disco
Nombre del SO del dispositivo: /dev/rdisk4
Perfil actual: BD-ROM
Fabricante: PIONEER
Producto: BD-RW BDR-UD04
Revisión: 1.11
Número de serie: TADL032997WL
Fecha del firmware: 2018-11-28
Marcas de cifrado bus: 1B
Highest AACS version: 77
Drive platform: RS8A10
Firmware version: 1.11
Is it possible patch?
Thanks very much
#540 Post by Coopervid » Fri Apr 07, 2023 4:58 pm
You must allow Internet access for Makemkv. That's it. Go to View Preferences General and check the box.
