Missing Titles on LionsGate DVD
JustSomeGuy
Post by JustSomeGuy »
I am on Mac OS X, tried version 1.17.2 and 1.171.3.
When scanning the DVD (Delicatessen) I get this output, with debug:
Launching /Applications/Capture Apps/MakeMKV_1.17.2.app/Contents/MacOS/mmgplsrv
DEBUG: Code 0 at _%SXZ,ljdE.zAAv}?&ui:29396460
003028:0000 Title #1 was added (20 cell(s), 1:39:12)
003028:0000 Title #4 was added (2 cell(s), 0:02:09)
003025:0000 Title #5 has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
However, WinX DVD ripper is able to see Titles 2 & 3 (8 and 13 minutes long respectively). Manual Mode does show the titles:
2: 2/1 - 2 chapter(s) 0:13:31 2 cell(s)
3: 3/1 - 2 chapter(s) 0:08:44 2 cell(s)
That this was kind of weird.
Re: Missing Titles on LionsGate DVD
Post by d00zah »
Try individual modes instead of 'Auto'... IIRC, 'CellTrim' might be a winner?
DVD opening modes - CellWalk, CellTrim, CellFull
JustSomeGuy
thanks! I will try that. I am a ripping newb, so I have not touched many of the settings.
Post by d00zah »
Lionsgate titles, in and of themselves, have been problematic. Add to that the reworked 'DVD processing engine', which has proven to be WIP. There will always be random issues & you do note 'Manual Mode' exposes the missing titles, so there are options when you encounter one.
JustSomeGuy
Also, you were spot on, doing a CellFull showed all titles, no problem. Thanks for the help.
