I am on Mac OS X, tried version 1.17.2 and 1.171.3.
When scanning the DVD (Delicatessen) I get this output, with debug:
Launching /Applications/Capture Apps/MakeMKV_1.17.2.app/Contents/MacOS/mmgplsrv
DEBUG: Code 0 at _%SXZ,ljdE.zAAv}?&ui:29396460
003028:0000 Title #1 was added (20 cell(s), 1:39:12)
003028:0000 Title #4 was added (2 cell(s), 0:02:09)
003025:0000 Title #5 has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
However, WinX DVD ripper is able to see Titles 2 & 3 (8 and 13 minutes long respectively). Manual Mode does show the titles:
2: 2/1 - 2 chapter(s) 0:13:31 2 cell(s)
3: 3/1 - 2 chapter(s) 0:08:44 2 cell(s)
That this was kind of weird.
Missing Titles on LionsGate DVD
Re: Missing Titles on LionsGate DVD
Try individual modes instead of 'Auto'... IIRC, 'CellTrim' might be a winner?
DVD opening modes - CellWalk, CellTrim, CellFull
JustSomeGuy
thanks! I will try that. I am a ripping newb, so I have not touched many of the settings.
Lionsgate titles, in and of themselves, have been problematic. Add to that the reworked 'DVD processing engine', which has proven to be WIP. There will always be random issues & you do note 'Manual Mode' exposes the missing titles, so there are options when you encounter one.
JustSomeGuy
Also, you were spot on, doing a CellFull showed all titles, no problem. Thanks for the help.
