UH12NS40
Johnqmalapert
UH12NS40
I have seen a couple threads where people got this drive able to rip 4k discs. I'm super confused by this process. I downloaded the bh14ns40 patch tool exe from this thread
viewtopic.php?t=19780
and used the included firmware bin file. It gave me the error at the end. Makemkv reports same data as before. pic below
I ran the SDtoolflasher (v1.3.5) but the only firmware in the "all you need fw pack" only had the WH16NS60 fw in it. Pic below. Should I use this?
Or should I use the cmd prompt instead as the YT video demos?
- 2023-03-11 21_02_13-Window.jpg (38.38 KiB) Viewed 10690 times
- original.jpg (104.83 KiB) Viewed 10690 times
Re: UH12NS40
it will probably work on wh16ns60 fw let us know and i'll update the guideJohnqmalapert wrote: Sun Mar 12, 2023 2:13 am I have seen a couple threads where people got this drive able to rip 4k discs. I'm super confused by this process. I downloaded the bh14ns40 patch tool exe from this thread
Johnqmalapert
Re: UH12NS40
no harm if it doesn't work?
Re: UH12NS40
could die but not likely as its mt1959
Johnqmalapert
Re: UH12NS40
Ok, seems to have worked (i think), pic below.
1st disk ripped successfully, while the 2nd/3rd have reported read errors. They seem to be hardware related. Does it seem that way to you? I've been using the backup option.
MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Backing up disc into folder "//diskstation/movies/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00013.m2ts' at offset '2187264000'
Failed to save title /BDMV/STREAM/00013.m2ts to file //diskstation/movies/
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '12924352512'
Failed to save title /BDMV/STREAM/00008.m2ts to file //diskstation/movies/
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 2 files failed hash check
Re: UH12NS40
Yeah you can try cleaning the discs other than that cleaning or replacing the drive
But I will add that drive to the guide
Johnqmalapert
Re: UH12NS40
thanks. Any resources on the best way to clean the drive?
Re: UH12NS40
yeah take it apartJohnqmalapert wrote: Sun Mar 19, 2023 4:53 pm thanks. Any resources on the best way to clean the drive?
only 4 screws hold it together and the front bezel unclips
then clean laser with alcohol and dry it
Johnqmalapert
Re: UH12NS40
@Billy fyi the drive/firmware does NOT work with DVDFab 12.1.0.1. It is giving errors about "unfriendly firmware".
Re: UH12NS40
i know that dvdfab bad anywayJohnqmalapert wrote: Mon Mar 20, 2023 2:23 am @Billy fyi the drive/firmware does NOT work with DVDFab 12.1.0.1. It is giving errors about "unfriendly firmware".
but if you want to use worse ripper go to wh16ns60 1.00 in my de pack
Johnqmalapert
Re: UH12NS40
Thanks! No I'm happy with mkv just sending that info for your documentation.
