Java
Motoxxx
Java
Post by Motoxxx »
Do I really need to install Java in order to properly use MakeMkv software? Is this the correct setup?
Thank in advance.
Screenshot 2023-03-19 022802.png (16.38 KiB) Viewed 3150 times
Re: Java
Have you come across any titles with 'fake playlists' or 'playlist obfuscation' yet?
What is the correct play list [insert title here]?
Blu-ray menus are rendered using Java. In a 'fake playlist' scenario, MakeMKV can use Java to attempt to figure out the correct playlist. Using it is optional, but it makes things nicer in these scenarios.
Further reading: "Fake playlist" protection - help needed
