Can't open .bdmv file
Timberflake1983
#1 Post by Timberflake1983 » Sun Mar 19, 2023 8:46 am
Hi all, having a weird problem whereby certain .bdmv files won't open.
I'm on Mac using v1.17.3, most of the time I can go into file>open file and then select the .bdmv I want to open but sometimes it doesn't work. For example I have The Prestige, I can the both both the index.bdmv and MovieObject.bdmv but when I try to open either of them nothing happens, makemkv does nothing, no error, nothing.
Has anyone else come across this? Not really sure how to fix it.
Re: Can't open .bdmv file
#2 Post by dcoke22 » Sun Mar 19, 2023 7:31 pm
Does MakeMKV give an error or output anything in the log when you open a BDMV folder and it doesn't work?
What's the provenance of your BDMV folders? In my workflow, I almost always make a decrypted backup up a blu-ray first with MakeMKV and use MakeMKV to open the BDMV folder and create .mkv files from that. I've never had one not work.
