Blu-Ray menus
Guitrdone
Blu-Ray menus
#1 Post by Guitrdone » Fri Mar 17, 2023 11:58 pm
As far as I can tell, MakeMKV copies the titles on a Blu-Ray, but doesn't copy the menu. Is there a way to preserve the menu from a disc? :D
Re: Blu-Ray menus
#2 Post by Billycar11 » Sat Mar 18, 2023 12:24 am
Guitrdone wrote: Fri Mar 17, 2023 11:58 pm As far as I can tell, MakeMKV copies the titles on a Blu-Ray, but doesn't copy the menu. Is there a way to preserve the menu from a disc? :D
The yellow folder on top be sure to check the decrypt box
Guitrdone
Re: Blu-Ray menus
#3 Post by Guitrdone » Sat Mar 18, 2023 1:18 am
Thanks. Sorry I'm such a dunce, but the only yellow folder I see is the one to select an output destination. What am I missing? :?
Re: Blu-Ray menus
#4 Post by Billycar11 » Sat Mar 18, 2023 1:34 am
yeah thats where it will save just click on and with the decrypt box checked and it will start copying the whole disc
Guitrdone
Re: Blu-Ray menus
#5 Post by Guitrdone » Sat Mar 18, 2023 3:38 am
Thanks. I don't see a decrypt button anywhere in MakeMKV. And the yellow folder button just opens the save location dialog. :(
Re: Blu-Ray menus
#6 Post by dcoke22 » Sat Mar 18, 2023 4:29 am
Guitrdone wrote: Sat Mar 18, 2023 3:38 am Thanks. I don't see a decrypt button anywhere in MakeMKV. And the yellow folder button just opens the save location dialog. :(
It should look like this:
Guitrdone
Re: Blu-Ray menus
#7 Post by Guitrdone » Sat Mar 18, 2023 4:50 am
Thanks for helping. That button is greyed out for all the Blu-Rays I've looked at so far. I'm licensed and registered so I'm thinking everything should be turned on.
Re: Blu-Ray menus
#8 Post by Billycar11 » Sat Mar 18, 2023 4:58 am
you do it before clicking the disc
Guitrdone
Re: Blu-Ray menus
#9 Post by Guitrdone » Sat Mar 18, 2023 2:16 pm
Thanks, I found it. Sorry for being so needy!
