Blu-Ray menus
Guitrdone
Blu-Ray menus
As far as I can tell, MakeMKV copies the titles on a Blu-Ray, but doesn't copy the menu. Is there a way to preserve the menu from a disc?
Re: Blu-Ray menus
The yellow folder on top be sure to check the decrypt boxGuitrdone wrote: Fri Mar 17, 2023 11:58 pm As far as I can tell, MakeMKV copies the titles on a Blu-Ray, but doesn't copy the menu. Is there a way to preserve the menu from a disc?![]()
Guitrdone
Re: Blu-Ray menus
Thanks. Sorry I'm such a dunce, but the only yellow folder I see is the one to select an output destination. What am I missing?
Re: Blu-Ray menus
yeah thats where it will save just click on and with the decrypt box checked and it will start copying the whole disc
Guitrdone
Re: Blu-Ray menus
Thanks. I don't see a decrypt button anywhere in MakeMKV. And the yellow folder button just opens the save location dialog.
Re: Blu-Ray menus
It should look like this:Guitrdone wrote: Sat Mar 18, 2023 3:38 am Thanks. I don't see a decrypt button anywhere in MakeMKV. And the yellow folder button just opens the save location dialog.![]()
Guitrdone
Re: Blu-Ray menus
Thanks for helping. That button is greyed out for all the Blu-Rays I've looked at so far. I'm licensed and registered so I'm thinking everything should be turned on.
Re: Blu-Ray menus
you do it before clicking the disc
Guitrdone
Re: Blu-Ray menus
Thanks, I found it. Sorry for being so needy!
