Blu-Ray menus
Guitrdone
Blu-Ray menus
Post by Guitrdone »
As far as I can tell, MakeMKV copies the titles on a Blu-Ray, but doesn't copy the menu. Is there a way to preserve the menu from a disc? :D
Re: Blu-Ray menus
Guitrdone wrote: Fri Mar 17, 2023 11:58 pm As far as I can tell, MakeMKV copies the titles on a Blu-Ray, but doesn't copy the menu. Is there a way to preserve the menu from a disc? :D
The yellow folder on top be sure to check the decrypt box
Guitrdone
Re: Blu-Ray menus
Post by Guitrdone »
Thanks. Sorry I'm such a dunce, but the only yellow folder I see is the one to select an output destination. What am I missing? :?
Re: Blu-Ray menus
yeah thats where it will save just click on and with the decrypt box checked and it will start copying the whole disc
Guitrdone
Re: Blu-Ray menus
Post by Guitrdone »
Thanks. I don't see a decrypt button anywhere in MakeMKV. And the yellow folder button just opens the save location dialog. :(
Re: Blu-Ray menus
Guitrdone wrote: Sat Mar 18, 2023 3:38 am Thanks. I don't see a decrypt button anywhere in MakeMKV. And the yellow folder button just opens the save location dialog. :(
It should look like this:
Guitrdone
Re: Blu-Ray menus
Post by Guitrdone »
Thanks for helping. That button is greyed out for all the Blu-Rays I've looked at so far. I'm licensed and registered so I'm thinking everything should be turned on.
Re: Blu-Ray menus
you do it before clicking the disc
Guitrdone
Re: Blu-Ray menus
Post by Guitrdone »
Thanks, I found it. Sorry for being so needy!
