Ultimate UHD Drives Flashing Guide Updated 2025
Hellboy. wrote:
Fri Mar 17, 2023 4:09 pm
If i rip a 4k movie and remove the protection, and then burn the movie in a disk, the movie work in a PC?
If you burn it right, sure. But why would you? Copy the .mkv across the network to the new PC or put the file on a USB stick and sneaker net it to the new PC.
sn0wleo
Post by sn0wleo »
sdunlap1 wrote:
Wed Mar 15, 2023 4:16 am
sn0wleo wrote:
Tue Mar 14, 2023 5:08 pm
I have an LG Drive with the following specs can I flash it to read UHD Disks ?
Product: BD-RE BH16NS40
Revision: 1.05
Serial number:
Firmware date: 2120-05-06 13:31
Highest AACS version: 77
Just flashed this drive on a Mac with WH16NS60 firmware. Ripping away now.
I just tried to do it but it doesnt show me everything when I run the first command to show my drive all I get is
Found 1 drives(s)
00:
HL-DT-ST_BD-RE__BH16NS40_1.05_212005061331_KLLM4DA2425
dcoke22 wrote:
Fri Mar 17, 2023 7:09 pm
You need to know that everybody who wants the best quality only rips to ISO or folder to play it with an Oppo or Oppo clone. And then the mkv output is not the best solution for everybody. But burning to BDs is outdated, I agree.
Hellboy.
Post by Hellboy. »
Coopervid wrote:
Fri Mar 17, 2023 9:12 pm
What Oppo or Oppo clone is recommended. What is the least expensive?
I understand and I agree. I should be more clear in my answer. Using either the .mkv or the decrypted backup or an ISO is most likely more convenient than burning a disc.
Hellboy. wrote:
Fri Mar 17, 2023 11:48 pm
The Oppo clone M9201 is recommended. Oppo has stopped production of Bluray players.
Look here or depending on your location you can also check on ebay etc. Use Google.
https://foro.avpasion.com/t/comprar-m97 ... oppo.2469/
Hellboy.
Post by Hellboy. »
Just for knowledge, what is the correct way to burn the movie?
Thanks for the link Coopervid.
Hellboy. wrote:
Sat Mar 18, 2023 6:02 pm
Usually 25GB discs are no issue with any drive. If you burn 50GB discs read this:
https://forum.redfox.bz/threads/the-lon ... -tl.86133/
You load the BDMV and the CERTIFICATE folder in Imgburn. To reduce size if it exceeds 50GB you need commercial software like CloneBD as an example. 50GB is the limit. Only one player can handle larger discs.
rellog321
Post by rellog321 »
Good Afternoon All,
I'm trying to flash a new LG WH16NS40 to the most recent 102 MK file. However, it does not seem to be working. I cannot see if I have all the settings set up because the app is crushed into a tiny box. I'm using Windows 11 64 bit.Image
Screenshot 2023-03-26 142756.jpg (43.32 KiB) Viewed 22325 times
Post by d00zah »
rellog321 wrote:
Sun Mar 26, 2023 7:29 pm
Good Afternoon All,
viewtopic.php?p=114370#p114370
rellog321
Post by rellog321 »
No go with that method. The window completely disappears with those settings. Oh, and I realized I'm on Windows 10, not 11- if that matters....
Post by d00zah »
rellog321 wrote:
Sun Mar 26, 2023 9:01 pm
Interesting. Probably best addressed in SDFtool Flasher where the author might have some additional insight. I see he added the note:
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
so it might be something unique to your setup?
heralded
Post by heralded »
I'm completely new to this forum as well as MakeMKV
I just received the 50th Anniversary box set of Pink Floyd's DSOTM, and I am looking to rip the Blu-Ray Dolby Atmos, Blu-Ray Dolby ATS, and DVD disks.
I'm starting with the Blu-Ray disks.
I'm doing this from a MacMini running 13.1
I just acquired the Archon MD-8107S-U3YC-UHD external drive.
I already used MakeMKV to rip the first Blu-Ray to the file system. The first thing that I encountered was that the MakeMKV app would not allow me to select the Save selected titles icon, so I couldn't see the audio tracks.
I want to upgrade the firmware
Since, I am on a Mac, I am trying to use the sdftool from the CLI.
This the drive info from sdftool
MacMini-Server:MacOS jjosephs$ ./sdftool --drive=HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO6M2QB3331 --info
DEBUG: code=00000000 src=VZBHBBy+W_XF|V2fQjF-gVPZp:29395149
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:1.02
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:BA3AA52BF4C5
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N     1.02:R000200:-
This is what I am getting:
$ pwd
/Applications/MakeMKV.app/Contents/MacOS
$ ./sdftool --drive=HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO6M2QB3331 --sdf-file=/Users/username/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ slim\ BU40N/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin -v
Unable to load sdf.bin
Internal error 0x981000ce
I thought that maybe sdftool needs for the file to be sdf.bin, so I copied
to
sdf.bin
$ ./sdftool --drive=HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO6M2QB3331 --sdf-file=/Users/jjosephs/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ slim\ BU40N/sdf.bin -v
Thank you for your help!
BR,
Jerald
Post by d00zah »
heralded wrote:
Tue Mar 28, 2023 7:41 am
BR,
Jerald
Add enc to the command line... 2020+ FWs are encrypted.
andrewtopher
Post by andrewtopher »
LG BP60Nb10 with SVC NB12 using a Mac M1 to flash. I have followed the guide and to no avail! MakeMKV tells me the disk cannot be decrypted. I have tried 3 different LG firmware options out of the all you need firmware pack. Can someone point me in the right direction? Which exact firmware should I be selecting?
Screenshot 2023-03-30 at 4.27.15 PM.png (137.32 KiB) Viewed 35661 times
Screenshot 2023-03-30 at 4.26.50 PM.png (264.07 KiB) Viewed 35661 times
