I have a new PC with Windows 11 so I installed the latest MakeMKV beta (v1.17.3).
However, fresh from install it cannot open most DVDs I try.
It did open one disc but failed to rip:
MakeMKV v1.17.3 win(x64-release) started
Title #1 was added (18 cell(s), 1:26:15)
Saving 1 titles into directory C:/Users/NickRamsey/Videos
Error 'OS error - This device does not exist' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
Failed to save title 0 to file C:/Users/NickRamsey/Videos/A1_t00.mkv
0 titles saved, 1 failed
All the discs I have tried are ones I have already ripped with the same version of MakeMKV on my Windows 10 machine using the same USB BR/DVD drive.
BD-ROM Slimtype BD E DS4E1S EA17 004260040586
Why would the same drive, with the same discs and the same version of MakeMKV work perfectly on Windows 10 but not on a brand new Windows 11?
New install on Windows 11 cannot open most DVDa
Re: New install on Windows 11 cannot open most DVDa
because your band new windows 11 pc does not put out enough power on the usb ports for an optical rive
https://www.amazon.com/gp/product/B0797 ... R7PE&psc=1
a powered usb hub may help
Interesting!
The port is specified to charge external devices at 3.0A so one would assume it could supply sufficient power for a USB optical drive...
Edit: Quite right though, plugged in another port and Bingo! Looks like I have a faulty port on a new machine.
