Ultimate UHD Drives Flashing Guide Updated 2025
tegid1977
Post by tegid1977 »
I have tried several methods to flash my Archgon MD-8107-U3 so far with no luck. Here is the information I get from MakeMKV:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO8M2QI0627
Bus encryption flags: 1F
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I've tried flashing HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin from the old directory of mk-firmware-pack-20200720 if I run the CLI command
makemkvcon64.exe f --all-yes -d D: rawflash -i "HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin"
I get what appears to be a successful message:
Reading input file HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO8M2QI0627
 100% Operation finished
Done successfully
But when I restart my computer and run MakeMKV again the drive info is unchanged. I know I am missing something and would appreciate any help that can be given.
As to why I ran the CLI and not a GUI the GUI would fail immediately see attachments for a screenshot.
Screenshot 2023-03-13 184207.png (158.05 KiB) Viewed 23278 times
tegid1977 wrote:
Mon Mar 13, 2023 11:44 pm
Revision: 1.02
Done successfully
Your firmware is encrypted. Add the enc flag to your command.
sn0wleo
Post by sn0wleo »
I have an LG Drive with the following specs can I flash it to read UHD Disks ?
Product: BD-RE BH16NS40
Revision: 1.05
Serial number:
Firmware date: 2120-05-06 13:31
Firmware version: 1.05
Yes. Use the guide from page 1. You need to flash MK firmware. DE firmware is only possible afterwards but is not needed.
tegid1977
Post by tegid1977 »
Thanks Marty! I added the ENC indicator but now its failing before its done sending the firmware.
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash enc -i "HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin"
  98% .................................................
Write DRAM NG 05/26/03
Command produced error code 0x82052603
tegid1977 wrote:
Wed Mar 15, 2023 12:40 am
seen that before either its a whatever error or the case is bad and it cant be flashed through it, recheck your drive info in makemkv see if it flashed it likely did happens alot with amd usb drivers
tegid1977
Post by tegid1977 »
No luck still shows unpatched in makemkv. Does that mean this drive wont work with uhd for makemkv?
sdunlap1
Post by sdunlap1 »
sn0wleo wrote:
Tue Mar 14, 2023 5:08 pm
Revision: 1.05
Serial number:
Just flashed this drive on a Mac with WH16NS60 firmware. Ripping away now.
tegid1977 wrote:
Wed Mar 15, 2023 2:50 am
Your not using 1.03 like the guide says missed that the first time :roll:
Billycar11 wrote:
Wed Mar 15, 2023 1:04 pm
BU40N 1.03 is in the OLD folder of the firmware pack.
tegid1977
Post by tegid1977 »
That did it! Thank you!!
Hellboy.
Post by Hellboy. »
Hello i new here. I read a few page and if i understand, if i buy a PIONEER BDR-XD08UMB-S and it have the firmware v1.03, the drive just work without doing anything to it?
Thanks.
dinesh
Post by dinesh »
I am currently using the drive "archgon Star UHD External 4K-Ultra HD BD Player" to rip blu rays.
I can only rip blu-rays, but it doesn't work for 4K UHD discs at all. I will need to flash the drive.
Product details: https://www.amazon.co.uk/Archgon-Extern ... 101&sr=1-3
This is the info of the drive:
I downloaded a folder for firmware pack and found the following:
1) Asus 5.25 BW-16D1HT
2) LG 5.25 desktop
3) LG slim BP50NB40-NB50
4) LG slim BU40N
5) LG slim USB BP60NB10
Could someone please suggest which .bin file to use (that would ensure I can be successful with the ripping process)?
What does the Drive Information section say? It is above the LibreDrive Information.
Hellboy.
Post by Hellboy. »
Thanks.
Edit
If i rip a 4k movie and remove the protection, and then burn the movie in a disk, the movie work in a PC?
