I have a Japanese Bluray movie that MakeMKV get stuck on when trying to read the disc.
If I open MakeMKV first and then insert the disc, MakeMKV stuck on loading.
If I insert the Disc first and then open MakeMKV, it stuck on Scanning CD-ROM devices.
I tried it on different version of Mac OS and Windows on different computers with same issue.
I can play the disc using VLC without any issues. I can play the disc on my PS5 without any issues.
MakeMKV loads other Bluray movies fine.
Below is the debug output. Any idea what could be causing this?
Debug log started at Wed Mar 15 10:30:44 2023 , written by MakeMKV v1.17.3 darwin(x64-release)
001005:0000 MakeMKV v1.17.3 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/user/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin19.0) , proxy server not set.
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-XS07U 1.01 BJDL300099UCd" opened in OS access mode.
SDF v098: PIONEER_BD-RW__BDR-XS07U_1.01_BJDL300099UC
MakeMKV stuck on scanning or loading this Japanese Bluray movie
renovatio522
Ezatoka
Re: MakeMKV stuck on scanning or loading this Japanese Bluray movie
Is this a normal BluRay or a UHD?
If a normal BluRay maybe aacs info can give some information about the disk: (Virustotal link)
Can't imagine there's an AACS info, that MakeMKV can't handle but one never knows.It's a command line tool:
Usage: aacs_info <path-to-disc-root>
renovatio522
Bluray - At least that is what it says on the box. It doesn't mention anything about UHD.
Also there is no AACS folder on the Disc. Just BDMV and CERTIFICATE folders only.
C:\Users\User\Downloads\aacs_info\aacs_info>aacs_info D:
Opening D: using libaacs 0.11.1 ...
../libaacs-0.11.1/src/libaacs/aacs.c:464: Unable to open AACS\Content000.cer
../libaacs-0.11.1/src/libaacs/aacs.c:464: Unable to open AACS\Content001.cer
../libaacs-0.11.1/src/libaacs/aacs.c:1143: Failed to read content certificate file
../libaacs-0.11.1/src/libaacs/aacs.c:1152: Failed to read Bus Encryption Enabled flag from content certificate file
../libaacs-0.11.1/src/libaacs/aacs.c:464: Unable to open AACS\Unit_Key_RO.inf
../libaacs-0.11.1/src/libaacs/aacs.c:464: Unable to open AACS\DUPLICATE\Unit_Key_RO.inf
../libaacs-0.11.1/src/libaacs/aacs.c:1121: Failed to read unit key file (AACS/Unit_Key_RO.inf)
libaacs open failed: Corrupt disc
../libaacs-0.11.1/src/libaacs/mmc.c:582: Unable to read VID from drive!
../libaacs-0.11.1/src/libaacs/aacs.c:1545: aacs_get_vid() failed
../libaacs-0.11.1/src/libaacs/aacs.c:504: Unable to open AACS\MKB_RO.inf
../libaacs-0.11.1/src/libaacs/aacs.c:504: Unable to open AACS\DUPLICATE\MKB_RO.inf
../libaacs-0.11.1/src/libaacs/aacs.c:567: Error reading MKB file (AACS/MKB_RO.inf)
../libaacs-0.11.1/src/libaacs/aacs.c:652: Error calculating media key - Failed opening MKB
../libaacs-0.11.1/src/libaacs/aacs.c:1520: aacs_get_mk() failed
Disc ID: ???
VID : ???
MK : ???
MKBv : 0
PMSN : ???
Bus encryption:
Device support: yes
Enabled in media: no
Content Certificate ID: ???
BD-J Root Cert hash: ???
Device binding ID: BA80279AE21E6DF9C286F804A67F37E3
Host Revocation List (MKB version 66):
000000000001 - 0000000003e8
000080000001 - 0000800080e8
015380013c69 - 015380018a88
06d580000015 - 06d580000028
270f80000001 - 270f80000bb8
ff2210100001 - ff221010001f
ff2210400001 - ff221040001f
ff2220000001 - ff22200000ff
ff2290100001 - ff229010001f
ff2290400001 - ff229040001f
ff22a0000001 - ff22a00000ff
ff2318000001 - ff231800001f
ff2318100001 - ff231810001f
ff2318400001 - ff231840001f
ff2340000001 - ff23400000ff
ff2710000001 - ff271000001f
ff2790000001 - ff279000001f
ffff0000000b - ffff00000014
ffff00000016
ffff00000021 - ffff0000002a
ffff00000035 - ffff00000038
ffff0000004e - ffff00000052
ffff00000054 - ffff00000057
ffff0000005d - ffff00000066
ffff00000080
ffff00000088 - ffff00000091
ffff00000094
ffff000000ae
ffff000000b2 - ffff000000bb
ffff000027db
ffff00002817
ffff00002820
ffff00002834 - ffff0000283d
ffff00002846
ffff0000284b
ffff80000001 - ffff80000024
ffff80000029
ffff8000002f
ffff80000039
ffff80000045
ffff80000053
ffff80000071
ffff80000079
ffff8000007c - ffff8000007e
ffff800000ad
ffff800000c4 - ffff800000c6
ffff800000d0
ffff800000f4 - ffff800000fd
ffff8000012d - ffff8000012e
ffff80000146
ffff80000153 - ffff80000154
ffff80000174
ffff80000189
ffff80000196 - ffff80000197
ffff800001b4
ffff800001c0
ffff800001d2
ffff800001e9
ffff800001eb
Drive Revocation List (MKB version 66):
000080000001 - 0000800055f0
270f20000001 - 270f20000514
270f80000001 - 270f800007d0
ff2600000001 - ff2600000096-
Ezatoka
Thats interesting. I have not seen an official movie BluRay yet without AACS. I have one with AACSv1. probably just for the company to be able to print "this disc is copy protected" onto it or something.renovatio522 wrote: Wed Mar 15, 2023 5:39 pm Bluray - At least that is what it says on the box. It doesn't mention anything about UHD.
Can you try to copy the contents of the BluRay onto the hard disk and with MakeMKV then you go File -> Open files -> from your copy select BDMV\index.bdmv as file to open.
renovatio522
I was able to copy the contents of the Bluray onto hard drive. Had to use Teracopy to copy otherwise drive will constantly make noises.
I was also able to open the index.bdmv file and extract the main movie. However, it did not finish extracting and would get stuck.
It had lots of
"source file is corrupt or invalid at offset, attempting to work around" error
and
"Too many AV synchronization issues in file"
How do I get Makemkv not to load the disc but instead let me select the index.bdmv directly from the Disc?
It had lots of
and
Ezatoka
I'm afraid that's something I don't know. Maybe via the command line aka makemkvcon64.exerenovatio522 wrote: Thu Mar 16, 2023 5:39 pm How do I get Makemkv not to load the disc but instead let me select the index.bdmv directly from the Disc?
If it would be my disk, I probably would try now to take MkvToolnix and add the index.bdmv to it. Then it'll scan all playlists and one could try to select the Main movie there and mix it into a MKV (can also deselect unwanted languages there).
renovatio522
I was able to figure out a way around it. Disconnect the Bluray drive, launch MakeMKV so it does not detect the drive, plug the Bluray drive back in, then use the open file to open the index.bdmv directly from the disc. Right now it is still trying to extract the movies and is taking a long time and also having same errors.
Not sure about the MkvToolnix, let me do research on that. Thank you for your assistance!!!
Yggdrasil
I to am having trouble with a Japanese blu. A tokusatsu show from the 60s, still 4:3 format, so you wouldn't expect remastered quality. It just so happens to be burnt onto a blu ray disc instead of a DVD.renovatio522 wrote: Fri Mar 17, 2023 7:36 am I was able to figure out a way around it. Disconnect the Bluray drive, launch MakeMKV so it does not detect the drive, plug the Bluray drive back in, then use the open file to open the index.bdmv directly from the disc. Right now it is still trying to extract the movies and is taking a long time and also having same errors.
What make of drive do you have? Mine is an external Hitachi-LG and it has no problems reading region A/B blu's,as it's a multi region blu ray/writer.
Disc isn't recognised and I just get a message in MKV - No disc inserted.
I've contacted Hitachi and they were no help. Asking if the disc was UHD.
