Re: UHD Drive having Trouble Reading Some 4K Discs.
Post by Woodstock » Wed Mar 15, 2023 12:44 pm
Without logs, it's impossible to say - you could have an issue with downloading keys, but that would show up in the logs.
(original message deleted because it was modified to be an attack message)
Michbeck
Post by Michbeck » Tue Mar 21, 2023 6:42 am
I have problems too. At this point it es impossible to open the Dune UHD disc.
MKB20_v76_Dune_6823.tgz
(183.03 KiB) Downloaded 271 times
Woodbeck
Post by Woodbeck » Fri Mar 24, 2023 5:36 pm
Make sure your discs are clean and if it still fails it could be a comms issue. To check a comms issue, run up a VPN on the machine and try again while the VPN is running. If it works there is an issue with IP or DNS filtering I imagine.
awdspyder
Post by awdspyder » Sat Mar 25, 2023 4:09 pm
I'll add to what Woodbeck stated and specifically say use a VPN with exit nodes in Asia. I have had the HK download fail from the US and Europe, but succeed from Japan.
cmosbum
Weak Laser? Re: UHD Drive having Trouble Reading Some 4K Discs.
Post by cmosbum » Mon Mar 27, 2023 7:12 pm
I was also could not make a back up of this disc, even after lots of cleaning. I looked at the disc and it's weaker than most as regards to strength of its fabrication. I'd used my drive a lot for CDs, so I decided to check whether the problem may be with the bluray reader. I installed my back=up UHD reader, which was new, and I no longer had a problem with the Dune 4K disc.
Try replacing your UHD Bluray drive with a new one.
