The Core 4k (Remastered)
htpc_rookie
Post by htpc_rookie »
Volume key not found. File submitted.
Fast Fizzy
Re: The Core 4k (Remastered)
Post by Fast Fizzy »
How long does this usually take?
The UHD FAQ has a entry for this question. It varies. Sometimes it is fast (a day or two), sometimes it is slow (a week or more).
MystiK
Post by MystiK »
I submitted my dump as well. How do we know when the key is ready?
Assuming you are set up to receive keys (there will be a warning when you start if downloads are blocked), you'll be able to process the disk. It's automatic, although not very vocal.
MystiK
Post by MystiK »
Woodstock wrote:
Wed Mar 15, 2023 2:17 am
That was my bad, I was being to generic with my Q. Yes I have the ability to fetch new keys enabled. What I should have said was is there any notification via email or on the forum that says the key is available? or is it a Try every so often til it works?
From your answer I see it is the latter that is probably more likely :) Thanks :)
If you think Mike sends notifications, that would be wrong as far as I know. It just starts working after a bit.
A guess at why that might be is that, if he gets the key early, it will start working for everyone, so sending out that many notices would be a pain. It's just the people who get disks early (the fun part) that would be "stuck" for a bit.
Fast Fizzy
FYI, The Core is working in MakeMKV right now.
MystiK
Post by MystiK »
Fast Fizzy wrote:
Wed Mar 15, 2023 10:42 pm
Funny I tried it about 10 mins ago, didn't work, seen you said it did tried again and it does LOL
