The Core 4k (Remastered)
htpc_rookie
#1 Post by htpc_rookie » Mon Mar 13, 2023 1:03 pm
Volume key not found. File submitted.
Fast Fizzy
Re: The Core 4k (Remastered)
#2 Post by Fast Fizzy » Tue Mar 14, 2023 6:01 pm
How long does this usually take?
#3 Post by dcoke22 » Tue Mar 14, 2023 7:20 pm
The UHD FAQ has a entry for this question. It varies. Sometimes it is fast (a day or two), sometimes it is slow (a week or more).
MystiK
#4 Post by MystiK » Wed Mar 15, 2023 2:01 am
I submitted my dump as well. How do we know when the key is ready?
#5 Post by Woodstock » Wed Mar 15, 2023 2:17 am
Assuming you are set up to receive keys (there will be a warning when you start if downloads are blocked), you'll be able to process the disk. It's automatic, although not very vocal.
MystiK
#6 Post by MystiK » Wed Mar 15, 2023 5:22 am
That was my bad, I was being to generic with my Q. Yes I have the ability to fetch new keys enabled. What I should have said was is there any notification via email or on the forum that says the key is available? or is it a Try every so often til it works?
From your answer I see it is the latter that is probably more likely :) Thanks :)
#7 Post by Woodstock » Wed Mar 15, 2023 12:40 pm
If you think Mike sends notifications, that would be wrong as far as I know. It just starts working after a bit.
A guess at why that might be is that, if he gets the key early, it will start working for everyone, so sending out that many notices would be a pain. It's just the people who get disks early (the fun part) that would be "stuck" for a bit.
Fast Fizzy
#8 Post by Fast Fizzy » Wed Mar 15, 2023 10:42 pm
FYI, The Core is working in MakeMKV right now.
MystiK
#9 Post by MystiK » Thu Mar 16, 2023 1:18 am
Funny I tried it about 10 mins ago, didn't work, seen you said it did tried again and it does LOL
