I have an LG Drive with the following specs can I flash it to read UHD Disks ?
Product: BD-RE BH16NS40
Revision: 1.05
Serial number:
Firmware date: 2120-05-06 13:31
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
sn0wleo
Yes. Use the guide from page 1. You need to flash MK firmware. DE firmware is only possible afterwards but is not needed.
tegid1977
Thanks Marty! I added the ENC indicator but now its failing before its done sending the firmware.
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash enc -i "HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin"
Reading input file HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO8M2QI0627
98% .................................................
Write DRAM NG 05/26/03
Command produced error code 0x82052603-
seen that before either its a whatever error or the case is bad and it cant be flashed through it, recheck your drive info in makemkv see if it flashed it likely did happens alot with amd usb driverstegid1977 wrote: Wed Mar 15, 2023 12:40 am Thanks Marty! I added the ENC indicator but now its failing before its done sending the firmware.
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash enc -i "HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin" Reading input file HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Sending image in encrypted format Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO8M2QI0627 Ready to write drive flash memory. (auto confirmed) Operation started: Sending flash image to drive 98% ................................................. Write DRAM NG 05/26/03 Command produced error code 0x82052603
tegid1977
No luck still shows unpatched in makemkv. Does that mean this drive wont work with uhd for makemkv?
sdunlap1
Just flashed this drive on a Mac with WH16NS60 firmware. Ripping away now.sn0wleo wrote: Tue Mar 14, 2023 5:08 pm I have an LG Drive with the following specs can I flash it to read UHD Disks ?
Revision: 1.05
Serial number:
Your not using 1.03 like the guide says missed that the first timetegid1977 wrote: Wed Mar 15, 2023 2:50 am No luck still shows unpatched in makemkv. Does that mean this drive wont work with uhd for makemkv?
BU40N 1.03 is in the OLD folder of the firmware pack.Billycar11 wrote: Wed Mar 15, 2023 1:04 pmYour not using 1.03 like the guide says missed that the first timetegid1977 wrote: Wed Mar 15, 2023 2:50 am No luck still shows unpatched in makemkv. Does that mean this drive wont work with uhd for makemkv?![]()
tegid1977
That did it! Thank you!!
Hellboy.
Hello i new here. I read a few page and if i understand, if i buy a PIONEER BDR-XD08UMB-S and it have the firmware v1.03, the drive just work without doing anything to it?
Thanks.
Thanks.
dinesh
I am currently using the drive "archgon Star UHD External 4K-Ultra HD BD Player" to rip blu rays.
I can only rip blu-rays, but it doesn't work for 4K UHD discs at all. I will need to flash the drive.
Product details: https://www.amazon.co.uk/Archgon-Extern ... 101&sr=1-3
This is the info of the drive:
Firmware version: 1.02
I downloaded a folder for firmware pack and found the following:
1) Asus 5.25 BW-16D1HT
2) LG 5.25 desktop
3) LG slim BP50NB40-NB50
4) LG slim BU40N
5) LG slim USB BP60NB10
Could someone please suggest which .bin file to use (that would ensure I can be successful with the ripping process)?
2) LG 5.25 desktop
4) LG slim BU40N
What does the Drive Information section say? It is above the LibreDrive Information.
Hellboy.
Thanks.
Edit
If i rip a 4k movie and remove the protection, and then burn the movie in a disk, the movie work in a PC?
Thanks.
Edit
If you burn it right, sure. But why would you? Copy the .mkv across the network to the new PC or put the file on a USB stick and sneaker net it to the new PC.Hellboy. wrote: Fri Mar 17, 2023 4:09 pm If i rip a 4k movie and remove the protection, and then burn the movie in a disk, the movie work in a PC?
sn0wleo
I just tried to do it but it doesnt show me everything when I run the first command to show my drive all I get issdunlap1 wrote: Wed Mar 15, 2023 4:16 amJust flashed this drive on a Mac with WH16NS60 firmware. Ripping away now.sn0wleo wrote: Tue Mar 14, 2023 5:08 pm I have an LG Drive with the following specs can I flash it to read UHD Disks ?
Revision: 1.05
Serial number:
Found 1 drives(s)
00:
HL-DT-ST_BD-RE__BH16NS40_1.05_212005061331_KLLM4DA2425
