I am using an ASUS BW-16D1HT. I followed the instructions in this forum to change the firmware so that LibreDrive mode is enabled -- firmware: 3.10. (Thank you all so much for the amazing instructions and program to make this happen!)
Everything works wonderfully until approximately 5-10 minutes into the saving process, it then freezes and gives me this error:
STATUS_DEVICE_NOT_CONNECTED
I have seen many posts about this code on here but I've found a weird difference: if I click anywhere on the dialogue screen every minute or so, this error does not occur and completes process just fine. It seems that my BD is timing out or something.
I did see in the "ultimate flashing guide" that there is a "sleep bug" mention and fix...though what I am encountering seems to be different than what is described there, and the fix does not make sense to me.
My question is: is there a known way to fix this particular sleep issue or will I just have to continue clicking every minute or so for every transfer?
ASUS BW-16D1HT Timeout Mid-transfer
Re: ASUS BW-16D1HT Timeout Mid-transfer
is this drive connected with usb in an external case?
Ilikethestars
Not a case but an external USB 3.0 DC powered Vantec SATA adaptor.
Try turning off USB selective suspending in your power planIlikethestars wrote: ↑Tue Mar 14, 2023 7:57 amNot a case but an external USB 3.0 DC powered Vantec SATA adaptor.
Ilikethestars
That did the trick! Thank you very much for the assistance, Billycar11.Billycar11 wrote: ↑Tue Mar 14, 2023 12:38 pmTry turning off USB selective suspending in your power planIlikethestars wrote: ↑Tue Mar 14, 2023 7:57 amNot a case but an external USB 3.0 DC powered Vantec SATA adaptor.
