ASUS BW-16D1HT Timeout Mid-transfer
Ilikethestars
#1 Post by Ilikethestars » Tue Mar 14, 2023 12:22 am
I am using an ASUS BW-16D1HT. I followed the instructions in this forum to change the firmware so that LibreDrive mode is enabled -- firmware: 3.10. (Thank you all so much for the amazing instructions and program to make this happen!)
Everything works wonderfully until approximately 5-10 minutes into the saving process, it then freezes and gives me this error:
STATUS_DEVICE_NOT_CONNECTED
I have seen many posts about this code on here but I've found a weird difference: if I click anywhere on the dialogue screen every minute or so, this error does not occur and completes process just fine. It seems that my BD is timing out or something.
I did see in the "ultimate flashing guide" that there is a "sleep bug" mention and fix...though what I am encountering seems to be different than what is described there, and the fix does not make sense to me.
My question is: is there a known way to fix this particular sleep issue or will I just have to continue clicking every minute or so for every transfer?
Re: ASUS BW-16D1HT Timeout Mid-transfer
#2 Post by Billycar11 » Tue Mar 14, 2023 12:54 am
is this drive connected with usb in an external case?
Ilikethestars
#3 Post by Ilikethestars » Tue Mar 14, 2023 7:57 am
Billycar11 wrote: Tue Mar 14, 2023 12:54 am is this drive connected with usb in an external case?
Not a case but an external USB 3.0 DC powered Vantec SATA adaptor.
#4 Post by Billycar11 » Tue Mar 14, 2023 12:38 pm
Ilikethestars wrote: Tue Mar 14, 2023 7:57 am
Try turning off USB selective suspending in your power plan
Ilikethestars
#5 Post by Ilikethestars » Tue Mar 14, 2023 7:25 pm
Billycar11 wrote: Tue Mar 14, 2023 12:38 pm
That did the trick! Thank you very much for the assistance, Billycar11.
