LibreDrive for Pioneer drives
Starfire
#496 Post by Starfire » Mon Mar 13, 2023 6:40 pm
in my old drives I found a Pioneer BDR-S09XLT which I had purchased in 2016. After reading this I had hopes it could be used for reading UHD discs.
So I hooked it up through a spare USB-adapter and ran MakeMKV. The drive is detected but MakeMKV doesn't display any LibreDrive Information - the whole section is just missing - the following is all that is displayed:
OS device name: R:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.51
Serial number: redacted
Highest AACS version: 53
On other drives I usually get the LibreDrive information even through the drive clearly doesn't support it, e.g. on a LG BD-RE GGW-H20L i get:
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: YL07-00
Is there anything that can be done for the BDR-S09?
#497 Post by Billycar11 » Mon Mar 13, 2023 8:34 pm
OS device name: R:
Revision: 1.51
Not for UHD
CNCisRobot
#498 Post by CNCisRobot » Tue Mar 14, 2023 4:55 pm
I have seen the post that said copy the data for a file sdf.bin. Should this file already exist and I add to it or do I need to create it and where would it go? If someone could help clear this up for me please.
Thank you
Darren.
zaqqaz6917
#499 Post by zaqqaz6917 » Thu Mar 16, 2023 5:12 pm
Just my two cents:
The Pioneer just seem to have Superior reading/ ripping capabilities compared to the LG at least. I had a disc that neither the internal nor external LG drives could read but the pioneer ripped it just fine
bestat
#500 Post by bestat » Sat Mar 18, 2023 9:31 pm
My Pioneer BDR-XS07 does not seem to like UHD disc(s). I have only tried one disc (Puss in Boots-The Last Wish) as all my others are in storage, a long way away. Blu-Ray works fine.
Any advice would be appreciated:
"That should work"
or "<pats user bestat on the head> Silly user, you forgot to... [insert obvious thing that apparently wasn't obvious]"
or "Yeah, known issue... working on it... please stand by..."
iMac Pro, running Ventura 13.2.1
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: [redacted]
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8E20
Firmware version: 1.01
hydroptix
#501 Post by hydroptix » Sun Mar 19, 2023 12:26 am
"That should work"
Revision: 1.01
Yep, same here. Just got a Pioneer BDR-XS07S and spits out the Knives Out 4k disc whenever I put it in. Regular Blurays work.
Revision: 1.01
Serial number: AFDL005871UC
Highest AACS version: 63
Probably currently watching Baby Driver on bluray, because all the streaming versions suck.
#502 Post by Coopervid » Sun Mar 19, 2023 12:34 am
You have no UHD capable drive.
outlier
#503 Post by outlier » Sun Mar 19, 2023 2:19 am
The black BDR-XS07UHD can handle 4K UHD without issue (I don’t recall my firmware version), though sounds like you’ve got the silver BDR-XS07S that isn’t expected to support 4K UHD.
TBD if firmware mods can eventually “fix” that but at this point I think people are still experimenting.
#504 Post by Billycar11 » Sun Mar 19, 2023 7:53 am
It's going to be possible to flash those xs07s drive to xs07uhd but you will have to wait a bit
bestat
#505 Post by bestat » Sun Mar 19, 2023 7:56 am
Ok. Thank you.
Trevor7
#506 Post by Trevor7 » Sun Mar 19, 2023 10:56 am
How can I get my XD05S to read 4k UHD?
OS device name: H:
Product: BD-RW BDR-XD05
Revision: 3.00
Serial number:
Firmware date: 2014-07-30
Highest AACS version: 66
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.00/ID34
#507 Post by MartyMcNuts » Sun Mar 19, 2023 9:35 pm
OS device name: H:
Revision: 3.00
Serial number:
You don't, unless a flashing tool for Pioneer drives is ever created and released publicly.
Even if that happens, your drive may possibly be too old anyway, since it has firmware from 2014 on it.
#508 Post by Coopervid » Sun Mar 19, 2023 10:17 pm
Like Marty said - very unlikely since your drive is dated 2014. You will need a newer one.
#509 Post by Billycar11 » Sun Mar 19, 2023 10:40 pm
there is still a lot to learn about crossflashing pioneers i have a pioneer 208 dbk form 2013 and it can read UHD after flashing
only 2 people in the world probably know the full list of drives that its possible on but the gist of it for now is if the drive platform is 8301+ it probably can see UHD when flashed.
but that does not mean it will be problem free some have lower quality picks ups and they wont rip BD100s or even BD66 marty found this out first hand so even if your drive can see a UHD does not mean it is useful for UHD.
#510 Post by Coopervid » Sun Mar 19, 2023 10:59 pm
Interesting... 209s are capable when crossflashed. This XD05 is quite old.
