Rabbit hole doesn't work for 1.6.8
thelangs
Post by thelangs » Sat May 14, 2011 2:36 pm
I saw the original post on this and it looked like it was fixed in 1.6.8. I opened this problem again not knowing if the solution is available or not.
I attached the screenshot of the error and sent the dump to svq@makemkv.com
setarip_old
Re: Rabbit hole doesn't work for 1.6.8
Post by setarip_old » Sun May 15, 2011 10:45 pm
Hi!
Since it appears that you have Automatic Downloading of SVQs turned off, did you try the suggested link?:
http://www.makemkv.com/svq/
thelangs
Post by thelangs » Sun May 22, 2011 11:32 pm
Thanks, I don't understand why I didn't see the box that stated a fix for Rabbit Hole. I Downloaded the svq file, however where does it go ?
thelangs
Post by thelangs » Tue May 24, 2011 10:34 pm
Never mind, I figured it out.
Rabbit Hole works with SVQ file
setarip_old
Post by setarip_old » Wed May 25, 2011 2:40 pm
Rabbit Hole works with SVQ file. Thanks.
You're quite welcome ;>}
herbcheck
Post by herbcheck » Sat Jun 11, 2011 8:12 am
How do I load the SVQ file in makeMKV in OS X?
