The Hot Zone (TV Series) 2011 Can’t open the DVD disc
ADeMeneghi
#1 Post by ADeMeneghi » Sat Mar 11, 2023 8:06 pm
I am using MakeMKV 1.17.3 for Mac OS X, and I am having problem to open the DVD for “The Hot Zone” (TV Series). I try 2 different disks sets, plus the first season includes 2 DVD’s, and I can’t open either one from each set.
I tried 2 different CD Rom drives (without success) and on the same computer/CD Rom I am capable to open multiple other DVD’s and Blu-Ray discs.
Does anyone know how to fix this issue,
Thanks,
Re: The Hot Zone (TV Series) 2011 Can’t open the DVD disc
#2 Post by dcoke22 » Sun Mar 12, 2023 3:55 am
You could try gently cleaning the discs. Sometimes if a disc is dirty or scratched it won't work properly.
ADeMeneghi
#3 Post by ADeMeneghi » Sun Mar 12, 2023 6:44 am
I try it too, I have a non-lint cloth that I use. Any of the 2 discs of each set open. And I try two diferentes sets. Any of the 4 discs open ??
#4 Post by Woodstock » Sun Mar 12, 2023 3:33 pm
What do you use for the solvent/cleaner? Using a cloth without some sort of solvent (disk soap in water, etc.) usually won't do much without AGGRESSIVE action, which is not recommended in most cases.
ADeMeneghi
#5 Post by ADeMeneghi » Tue Mar 14, 2023 8:54 pm
I use just a lint free cloth without any product
ADeMeneghi
#6 Post by ADeMeneghi » Tue Mar 14, 2023 9:22 pm
Here is the log:
MakeMKV v1.17.3 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.05 M00L8IB4925d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BH16NS40 1.05 KL7K7UG4819d" opened in OS access mode.
udf: udf_get_node: bad allocation extension size in udf_node
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
After that nothing happen is not able to open the disc
odin58
#7 Post by odin58 » Wed Mar 15, 2023 10:21 pm
DVD opening modes - CellWalk, CellTrim, CellFull.......try each mode manually. I had some that would only open in celltrim mode
#8 Post by Woodstock » Thu Mar 16, 2023 2:33 am
ADeMeneghi wrote: Tue Mar 14, 2023 8:54 pm I use just a lint free cloth without any product
I've rarely gotten a "clean cloth" to work for removing stuff from a disk. At most, it will smudge fingerprints, and anything actually stuck on the disk will still be stuck.
The errors you're receiving are usually caused by bad spots on the disk. Even breathing on it before using your clean cloth will help, but soapy water or (what I use) pledge-type cleaning/waxing fluid cuts through a lot more stuff. Don't go hog-wild on the cleaner, though.
