UH12NS40
Johnqmalapert
UH12NS40
Post by Johnqmalapert » Sun Mar 12, 2023 2:13 am
I have seen a couple threads where people got this drive able to rip 4k discs. I'm super confused by this process. I downloaded the bh14ns40 patch tool exe from this thread
viewtopic.php?t=19780
and used the included firmware bin file. It gave me the error at the end. Makemkv reports same data as before. pic below
I ran the SDtoolflasher (v1.3.5) but the only firmware in the "all you need fw pack" only had the WH16NS60 fw in it. Pic below. Should I use this?
Or should I use the cmd prompt instead as the YT video demos?
2023-03-11 21_02_13-Window.jpg (38.38 KiB) Viewed 10212 times
Re: UH12NS40
Post by Billycar11 » Sun Mar 12, 2023 2:33 am
Johnqmalapert wrote: Sun Mar 12, 2023 2:13 am I have seen a couple threads where people got this drive able to rip 4k discs. I'm super confused by this process. I downloaded the bh14ns40 patch tool exe from this thread
it will probably work on wh16ns60 fw let us know and i'll update the guide
Johnqmalapert
Re: UH12NS40
Post by Johnqmalapert » Sun Mar 12, 2023 2:51 am
no harm if it doesn't work?
Re: UH12NS40
Post by Billycar11 » Sun Mar 12, 2023 3:19 am
Johnqmalapert wrote: Sun Mar 12, 2023 2:51 am no harm if it doesn't work?
could die but not likely as its mt1959
Johnqmalapert
Re: UH12NS40
Post by Johnqmalapert » Thu Mar 16, 2023 2:47 pm
Ok, seems to have worked (i think), pic below.
2023-03-16 10_42_58-Window.jpg (39.98 KiB) Viewed 10111 times
1st disk ripped successfully, while the 2nd/3rd have reported read errors. They seem to be hardware related. Does it seem that way to you? I've been using the backup option.
MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Backing up disc into folder "//diskstation/movies/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00013.m2ts' at offset '2187264000'
Failed to save title /BDMV/STREAM/00013.m2ts to file //diskstation/movies/
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '12924352512'
Failed to save title /BDMV/STREAM/00008.m2ts to file //diskstation/movies/
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 2 files failed hash check
Re: UH12NS40
Post by Billycar11 » Thu Mar 16, 2023 11:55 pm
Yeah you can try cleaning the discs other than that cleaning or replacing the drive
But I will add that drive to the guide
Johnqmalapert
Re: UH12NS40
Post by Johnqmalapert » Sun Mar 19, 2023 4:53 pm
thanks. Any resources on the best way to clean the drive?
Re: UH12NS40
Post by Billycar11 » Sun Mar 19, 2023 5:05 pm
Johnqmalapert wrote: Sun Mar 19, 2023 4:53 pm thanks. Any resources on the best way to clean the drive?
yeah take it apart
only 4 screws hold it together and the front bezel unclips
then clean laser with alcohol and dry it
Johnqmalapert
Re: UH12NS40
Post by Johnqmalapert » Mon Mar 20, 2023 2:23 am
@Billy fyi the drive/firmware does NOT work with DVDFab 12.1.0.1. It is giving errors about "unfriendly firmware".
Re: UH12NS40
Post by Billycar11 » Mon Mar 20, 2023 2:30 am
Johnqmalapert wrote: Mon Mar 20, 2023 2:23 am @Billy fyi the drive/firmware does NOT work with DVDFab 12.1.0.1. It is giving errors about "unfriendly firmware".
i know that dvdfab bad anyway
but if you want to use worse ripper go to wh16ns60 1.00 in my de pack
Johnqmalapert
Re: UH12NS40
Post by Johnqmalapert » Fri Mar 24, 2023 6:43 pm
Thanks! No I'm happy with mkv just sending that info for your documentation.
