Pioneer BDR-209 Support
I'm new here and haven't been able to find info or update these drives (I have 2) that I pulled out of ASUS enclosures. I am using eSata enclosures from NextStar.
I am attaching info from MakeMKV.
Thanks for any help. Tried to search and got no results.
- Pioneer BDR-209 Info.jpg (61.03 KiB) Viewed 37933 times
Re: Pioneer BDR-209 Support
What reason do you need to "update" this drive? It already supports everything MakeMKV can get out it, and the latest Pioneer updates are killing the drives for ripping.
This actually can be flashed to do 4K it's just not available yet your going to just have to wait for a bit
Because it doesn't handle 4K. I've already tried.Woodstock wrote: Sat Mar 11, 2023 11:01 pm What reason do you need to "update" this drive? It already supports everything MakeMKV can get out it, and the latest Pioneer updates are killing the drives for ripping.
Thanks. I'll be a waiitn'. Is there some way that I could put myself on a list to be notified or where would I find the update?Billycar11 wrote: Sat Mar 11, 2023 11:15 pm This actually can be flashed to do 4K it's just not available yet your going to just have to wait for a bit
Re: ASUS BW-16D1X-U Pioneer BDR-209 Support
Hello, Has there been an update for this drive support that I missed? It will not handle UHD at the moment.
And yes, I have been searching the form for this. And also, sorry if I come off as rude. Its just me. I get teased about it at work. they call me Data and keep me on 3rd level support, far away from the customer.
If possible, I would like to open this drive. Wish I knew how to alter the BIN files.
Either way, the drive info in question is :
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Firmware date: 2017-12-21
Highest AACS version: 68
Drive platform: RS8601
Firmware version: E111/ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Email me about my $25 pioneer flasher I maybe able to helpJman9980 wrote: Sat Apr 29, 2023 9:15 pm Hello, Has there been an update for this drive support that I missed? It will not handle UHD at the moment.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
There is no public way of doing this
I am new to ripping 4k disks too.
Here the info for my drive.
Can someone please point me to tutorial I can follow to rip my 4k movies?
When I put in a 4k disk the drive just tries to read the disk and quits after a minute.Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Firmware date: 2018-05-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.51/ID61
the pioneer stuff is not public as its not mine to share i do have a paid for flasher to make that drive work though see below and email me about itwotdefcuk wrote: Fri Nov 03, 2023 7:11 pm I am new to ripping 4k disks too.
Revision: 1.51
keineahnung314
I bought a Pioneer 209D. It states that libredrive is enabled but it does not detect 4Ks. When I insert one it makes some noises but switches to "no disk inserted" after one minute. how can i flash it? Here is the Device Info:
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Highest AACS version: 12
Firmware version: 1.34/ID61
Revision: 1.34
Serial number:
PM sent.keineahnung314 wrote: Fri Dec 05, 2025 6:16 pm Hello,
Revision: 1.34
Serial number:
keineahnung314
Thanks for your PM. I started to backup an UHD. The Read rate is sticking constantly at 17.1M/s [4.0]. is this the maximum the drive can do or are there settings i have to tweak. the Source size is about 86G, which implies a triple layer Blu Ray.Coopervid wrote: Fri Dec 05, 2025 8:45 pmPM sent.keineahnung314 wrote: Fri Dec 05, 2025 6:16 pm Hello,
Revision: 1.34
Serial number:
All Pioneers are limited to 4x for UHDs.
AsianAttack
I'm interested a ls well
Post your Makemkv info.
Baronbuzby
OS device name: E:
Product: BD-RW BDR-209MIO
Revision: 1.30
Serial number: xxxxxxxxxxxx
Firmware date: 2015-10-30
Highest AACS version: 77
Drive platform: Pioneer RS8600
Firmware version: ID13
will this flash?
OS device name: E:
Revision: 1.30
will this flash?
