Ultimate UHD Drives Flashing Guide Updated 2025
z55575
#1651 Post by z55575 » Wed Mar 01, 2023 9:19 am
asmcom wrote:
Tue Feb 28, 2023 3:26 pm
z55575 wrote:
Tue Feb 28, 2023 12:08 pm
Hi there. Well my journey continues.
I have stumbled on a local ad for a Pioneer BDR-AD07BK (BK = Black colour).
Seller wants $80. It is in good visual condition. Since it's in person, I can test it to ensure it actually works and isn't a dud.
Just wondering if this would work with MakeMKV for UHD discs? The drive does not state UHD support, however it DOES support BDXL 3-layer (100GB) and 4-layer (128GB) discs, as well as Pureread/PureDrive v3 (whatever the name is). And I think Libredrive could be flashed based on the firmware list having AD07 listed.
This AD07 model seems to just be a non USB-C remodel of the BDR-XD07, additionally based on this blog I found comparing the two: https://beiznotes.org/difference-betwee ... -and-ad07/
AD07 is also missing the intelligent eco mode, which is not an issue for me.
Thank you.
Sent PM, be careful buying drives on Ali Express and Amazon.
Asmcom
Hi sorry for lack of clarity, it's being sold by a local chain of used computer/hardware stores. They provide a warranty and in-person testing, this would be an in person purchase, not online form Aliexpress or Amazon or similar. I already went through that with Mercari, never again.
I may also reach out to Pioneer to request a check on the serial number as I took photographs of it.
Mainly just wondering, if based on the specs of the AD07, if it's able to read UHD discs for MakeMKV, or if a drive explicitly needs to be labelled as "UHD Compatible" to read the discs at all.
I would of course test in the shop, but would rather avoid going back if needed.
Thank you!
#1652 Post by MartyMcNuts » Wed Mar 01, 2023 9:58 am
Thank you.
Asmcom
Thank you!
No, it reads blu-ray but not UHD.
alexbar
#1653 Post by alexbar » Fri Mar 03, 2023 6:53 pm
Hello everybody. My dream is to play UHD discs on PC. So, I have an Amd cpu, and I would like to know if this downgrade method is only for copying discs or also for playing directly through powerdvd, for example?
Bungle
#1654 Post by Bungle » Fri Mar 03, 2023 9:54 pm
I have always been able to play through Powerdvd with the flashed drives.
#1655 Post by Billycar11 » Sat Mar 04, 2023 12:08 am
You will never be able to play it officially in powerdvd but you can do direct playback from disc with makemkv integration with vlc jriver ect...
Motoxxx
#1656 Post by Motoxxx » Sat Mar 04, 2023 1:31 am
Hello, what is the minimum PC requirements to run makemkv software? I'm still running on a old PC with Pentium/Window 7
#1657 Post by Woodstock » Sat Mar 04, 2023 3:30 pm
Considering that some people run it on a Raspberry Pi, your PC should barely run it, but we don't know how long it will be supported. The 32-bit version is still included in the distribution for now.
You've come this far into the 21st century with a 20th century machine as your computer? I still have some for "special projects", but not as a human-interfaced machine...
Motoxxx
#1658 Post by Motoxxx » Sun Mar 05, 2023 2:26 am
Yeah, I don't used window PC that much. I have a Chromebook that used most of the time
#1659 Post by Woodstock » Sun Mar 05, 2023 4:28 am
Best bet would be to TRY it. This thread is about the drives, but MakeMKV should have no problem running on an older Win7 PC.
After you verify that it's working, you can decide on what drive you use going forward. Depending on what age you're talking about, the PC may have problems PLAYING a UHD file, but it should rip it no problem.
CNCisRobot
#1660 Post by CNCisRobot » Thu Mar 09, 2023 2:54 pm
Hi All, I have seen here it said pioneer drives should work, but I have a Pioneer BDR-UD04 with firmware version 1.2 and it does not work. Does this mean thats it no chance to get it to work in the future because of the current firmware as came from purchase.
I am new to the UHD side I always just used normal bluray and dvdfab and no problems but now I own a 4k tv I would love to see 4k films.
I have read a lot on here but I am disabled and on lots of medication so I get confused please accept my apology if I seem silly.
Darren.
jt5298
#1661 Post by jt5298 » Thu Mar 09, 2023 4:23 pm
I just downloaded the flasher tool. I am trying to downgrade my LG WH16NS40 to v 1.02. I get this error message write DRAM NG 5/26/03. It freezes up and I can't do anything. Can someone please help me try to figure this out?
efp722
Drive reads as "no disc"
#1662 Post by efp722 » Thu Mar 09, 2023 9:02 pm
Hey everyone,
I have a brand new LG WH16NS40 that was manufactured in August 2022. It came with 1.05 and I was able to get it down to WH16NS40 1.02, but when I insert a BD or UHD, it takes about 1-2 minutes to read it, but comes back as Type: No disc. Not sure where I went wrong or where to go from here. Any help is appreciated. Thanks!
#1663 Post by Billycar11 » Thu Mar 09, 2023 10:26 pm
Follow the guide it does not say to flash that firmware
jt5298
#1664 Post by jt5298 » Thu Mar 09, 2023 10:55 pm
Not sure I understand. My firmware is 1.04, I need to downgrade to 1.02 to make it UHD friendly. When I use the flasher tool I get this pop-up DRAM NG 5/26/03. Why am I getting this pop-up? How can I get it to downgrade successfully?
jt5298
#1665 Post by jt5298 » Fri Mar 10, 2023 1:06 am
Okay I downloaded the latest SDFtool Flasher 1.3.5. Tried to flash my drive and got this: Command produced error code 0x82052603. Is it just not possible to downgrade my drive?
