Cannot get Dolby Vision
FatherTime
Post by FatherTime » Thu Mar 09, 2023 5:35 pm
Ok. I feel really stupid. Either I'm REALLY bad at searching or my question hasn't been asked. First, total noob here. Not with tech, but with Makemkv. I cannot, for the life of me, get my rips to output Dolby Vision. I have the latest version of Makemkv, it reads fine an outputs the file correctly. I leave everything selected. When I look at the file (in the mediainfo app) only HDR10 shows. When I try to stream it the TV only gets an HDR10 signal. No DV to be found. I've tried to stream it across the local network to the Sony x700, Firestick 4k through the Kodi app and Plex app, as well as on the Sony TV Plex app. No DV to be found anywhere. I've tried ripping through Makemkv, and DVDFab with the same results. Completely lost and thinking this hobby isn't for me. Maybe just stick to playing the discs in the player. Lame. I am ripping with the LG Wh16ns40 with the correct firmware on a beast of a Windows 10 PC. Any help would be appreciated.
Re: Cannot get Dolby Vision
Post by dcoke22 » Thu Mar 09, 2023 7:16 pm
Make sure you have the latest version of MediaInfo.
Post by MartyMcNuts » Thu Mar 09, 2023 7:51 pm
Ok. I feel really stupid. Either I'm REALLY bad at searching or my question hasn't been asked. First, total noob here. Not with tech, but with Makemkv. I cannot, for the life of me, get my rips to output Dolby Vision. I have the latest version of Makemkv, it reads fine an outputs the file correctly. I leave everything selected. When I look at the file (in the mediainfo app) only HDR10 shows. When I try to stream it the TV only gets an HDR10 signal. No DV to be found. I've tried to stream it across the local network to the Sony x700, Firestick 4k through the Kodi app and Plex app, as well as on the Sony TV Plex app. No DV to be found anywhere. I've tried ripping through Makemkv, and DVDFab with the same results. Completely lost and thinking this hobby isn't for me. Maybe just stick to playing the discs in the player. Lame. I am ripping with the LG Wh16ns60 with the correct firmware on a beast of a Windows 10 PC. Any help would be appreciated.
Are you ripping a movie that actually contains DV? Not all UHD discs have DV.
FatherTime
Post by FatherTime » Thu Mar 09, 2023 8:27 pm
I have tried it with "Ready Player One" as well as "Dune". The "Ford vs Ferrari" works great because its HDR10. lol
FatherTime
Post by FatherTime » Thu Mar 09, 2023 8:59 pm
Yes, freshly downloaded and installed off the Mediainfo website.
Post by dcoke22 » Fri Mar 10, 2023 1:19 am
This is what MediaInfo version 21.09 shows me for my 4K rip of Dune (2021).
HDR format           : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Post by MartyMcNuts » Fri Mar 10, 2023 3:34 am
So your file has DV. Unfortunately, for now anyway, most players do not play DV in a MKV file. Most people mux the file as a mp4 / ts / m2ts file for playback on their DV compatible device. The container they use depends on what player they use.
quietvoid
Post by quietvoid » Fri Mar 10, 2023 4:28 am
Latest Plex won't let you play MakeMKV rips in Dolby Vision.
Also you need Kodi 21 to play these MKVs, and most of them won't work on a FireTV Stick 4K.
FatherTime
Post by FatherTime » Fri Mar 10, 2023 5:55 am
Can I play the mkv initially created through an Nvidia Shield Pro and get the Doby Atmos and Dolby Vision straight away or must I convert the mkv file to come other file type (like mp4) to stream it through a Sony x700 or some other device?
FatherTime
Post by FatherTime » Fri Mar 10, 2023 5:58 am
Will an Nvidia Shield Pro play that DV mkv file correctly? If I mux the file, what's the easiest way (which software) to do so? If mp4/ts/m2ts, will I lose any audio/video quiality? Also the DV is listed as Video 2 (1920x1080). hmmm
kweenie
Post by kweenie » Fri Mar 10, 2023 7:21 am
Yes. The Shield will play the file in DV, but it needs a DV capable player. Emby works, Kodi as well, but no experience myself, Plex is evil…. Also DV needs to be enabled in the settings.
rkhollister
Post by rkhollister » Fri Mar 10, 2023 10:54 am
Zidoo Z9X will also play DV MKV's - it is what I use for my 800+ title collection. Probably has the best PQ of the units out there but it is file playback only, not a streamer (i.e. no Netflix, Amazon, etc). The Dune players also work
FatherTime
Post by FatherTime » Fri Mar 10, 2023 3:17 pm
This is good news for me then. I was looking at getting a Zidoo Z9X over the Shield. I was going to plug into the Zidoo a multi-TB sata HDD and use it for 4k rip playback only. I already have a firestick 4k for streaming. From what I understand the Zidoo will play both MKV and ISO rips. Does that sound correct?
-Do you prefer mkv or iso on your Zidoo?
-Your preferred method of ripping to iso or mkv?
Post by dcoke22 » Fri Mar 10, 2023 4:26 pm
Dolby Vision is a complicated topic. Dolby Vision has a concept of profiles. DV Profile 5 is the profile used for streaming. If you have a streaming box like an Apple TV or Firestick or whatever that supports streaming things in Dolby Vision, that's the profile used.
Profile 7 is used for UHDs. Profile 7 can be further divided into titles that use MEL (minimal enhancement layer) or FEL (full enhancement layer). The enhancement layer is additional data that the player decodes and applies to the base layer during playback. Most streaming boxes can't do this. As I understand it, players like a Zidoo can use a MEL but do not work with a FEL. If they play a profile 7 DV file with a FEL, they'll ignore it.
There's a giant thread on this forum (Dolby Vision now possible through MP4 Mux.) talking about how to transform rips into a format that your player can play back with DV. Different playback setups have different needs. There are some quite knowledgeable folks posting in there as well as links to tools and tutorials. It is best read starting at the end and working backwards.
FatherTime
Post by FatherTime » Fri Mar 10, 2023 4:36 pm
Thats funny. I saw that thread and thought "580 pages????? What? Where would i start". Great info on the profile 5 & 7, thanks. I also saw a profile 8. Any idea on that? Come on technology!!!!!! All I wanna do is play a digital media on my tv with all the DV & DA just like a 4k disc work in a 4k player. Why you gotta be so difficult???? I still dont understand the MEL & FEL thing. My plan is to get a Zidoo, rip everything to mkv, and hope for the best. Is that a good plan??
