Rookie
Re: SDFtool Flasher
#676 Post by Rookie » Sat Feb 18, 2023 10:17 am
Hello @all,
unfortunately I also get this error message when I try to downgrade my new internal desktop drive ==> ASUS BC-12H2FT / firmware 3.12 to firmware 3.00 in the package.
It is a fresh Win11 installation, the app was started with a local admin user.
With Win10 before same procedure / same error.
With kind regards
Tommy
SDFtool_1_3_5_Errormessage .png (57.4 KiB) Viewed 21945 times
Re: SDFtool Flasher
#677 Post by Billycar11 » Sat Feb 18, 2023 3:33 pm
Rookie wrote: Sat Feb 18, 2023 10:17 am Hello @all,
With kind regards
Tommy
Flash to Asus 3.10 first
Rookie
Re: SDFtool Flasher
#678 Post by Rookie » Sat Feb 18, 2023 3:55 pm
Hello @all,
the solution was not to use the DE firmware but the MK firmware version.
==> DE firmware cannot downgrade from 3.12 | DE_ASUS_BC-12D2HT_3.00.bin
==> MK firmware successfully downgraded from 3.12 | ASUS-BC-12B1ST_b-3.11-WM00300-211902271321.bin
MK firmware version for ASUS_BC-12D2HT in version 3.11 works, first UHD BD-ROM read successfully.
After that I did not try the DE version at all.
with kind regards
Tommy
kurinukes
Re: SDFtool Flasher
#679 Post by kurinukes » Thu Feb 23, 2023 5:54 pm
Hello everyone,
recently came arcross this LibreDrive thing. Then I saw that apprently my drive is LibreDrive possible. Then came across the SDFtool to flash the firmware, but whenever I try to use, it just throws an Error (0x82052400). I tried searching online but couldn't find anything about it...
So I was wondering If anyone here has any idea what the error means or what maybe I could do about it?
I tried "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin" same error.
I tried "HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin" same error.
I aslo tried "DE_LG_BU40N_1.00.bin" same error.
Tried encryption on/off same error.
I'm kinda out off ideas..any help is welome. Much thanks.
I should add that it is an external Drive
Re: SDFtool Flasher
#680 Post by Coopervid » Thu Feb 23, 2023 10:30 pm
Most likely your chip in the enlosure doesn't support flashing.
danzerman
Re: SDFtool Flasher Net Framework Error
#681 Post by danzerman » Wed Mar 01, 2023 1:21 pm
hello I cannot open the installer any ideas anyone
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.5.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Registry
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
Re: SDFtool Flasher
#682 Post by SamuriHL » Wed Mar 01, 2023 3:56 pm
Do you have MakeMKV installed?
rupelja
Re: SDFtool Flasher
#683 Post by rupelja » Wed Mar 08, 2023 5:58 pm
Thanks for the info and the app.
Need help with the error message received. Drive is still good.
Perhaps I missed something in the forum posts.
Thanks for any assistance!
Everything looked good, but I encountered an error message:
Flash error - 8-3-2023.PNG (45.37 KiB) Viewed 21504 times
Re: SDFtool Flasher
#684 Post by Billycar11 » Wed Mar 08, 2023 7:32 pm
rupelja wrote: Wed Mar 08, 2023 5:58 pm Thanks for the info and the app.
Follow the guide recommend fw
rupelja
Re: SDFtool Flasher
#685 Post by rupelja » Wed Mar 08, 2023 8:20 pm
Billycar11 wrote: Wed Mar 08, 2023 7:32 pm
Would that recommendation be referring to the encrypted process or loading a MK firmware version.
If it is the MK firmware version, could you specify which one to use?
Thanks for your help.
Re: SDFtool Flasher
#686 Post by MartyMcNuts » Thu Mar 09, 2023 4:40 am
rupelja wrote: Wed Mar 08, 2023 8:20 pm
Both. Your issue is you are trying to flash directly from an encrypted firmware to WH16NS40 1.02 which can't be done. As per the guide, any desktop drive with encrypted firmware should be flashed to WH16NS60 1.02-MK first (which removes encryption and re-enables firmware downgrading). Then if you don't want to use the NS60 1.02-MK firmware, you can flash to something else.
eksine
Re: SDFtool Flasher
#687 Post by eksine » Thu Apr 06, 2023 3:03 am
Thanks so much marty mcnuts for making this tool, it worked great. Just confirming I was using asus bw-16dht inside a vantec nexstar DX2 (this is the newer one with 3amp power supply, not the older DX 2A supply) plugged into my front header usb 3.2 gen 1 (5gbps) on my B550 AORUS ELITE AX V2 (rev. 1.1)mobo. made a dump of the original firmware 3.10 and flashed the MK 3.10 firmware, MKV recognizes the microcode reenabled so I'm off to leearn how to rip and reencode! I don't even know why I'm doing this, I make $8,000/ month driving trucks, I could buy like every bluray and dvd ever made, plus 9anime has all the cartoons I usually watch anyways.
Mr_Orange
Re: SDFtool Flasher
#688 Post by Mr_Orange » Thu Apr 06, 2023 12:56 pm
eksine wrote: Thu Apr 06, 2023 3:03 am Thanks so much marty mcnuts for making this tool, it worked great. Just confirming I was using asus bw-16dht inside a vantec nexstar DX2 (this is the newer one with 3amp power supply, not the older DX 2A supply) plugged into my front header usb 3.2 gen 1 (5gbps) on my B550 AORUS ELITE AX V2 (rev. 1.1)mobo. made a dump of the original firmware 3.10 and flashed the MK 3.10 firmware, MKV recognizes the microcode reenabled so I'm off to leearn how to rip and reencode! I don't even know why I'm doing this, I make $8,000/ month driving trucks, I could buy like every bluray and dvd ever made, plus 9anime has all the cartoons I usually watch anyways.
Rip, yes, but why reencode?
I think you'll find that MakeMKV needs a disc from which to rip something...... this pretty much implies that you need to buy the disc first.
mike23
Re: SDFtool Flasher
#689 Post by mike23 » Sun Apr 09, 2023 6:26 pm
Greetings all!
I thought this would be a snap but doing something wrong ^_^
When trying to dump firmware, the file dumps as a .tar file, if I extract the tar file should I select one of the following .bin files to recover? Attempting the recovery method.
Issue of course is getting the No disc inserted error.
Screenshot 2023-04-09 112336.jpg (52.61 KiB) Viewed 20867 times
Screenshot 2023-04-09 112212.jpg (16.15 KiB) Viewed 20867 times
Re: SDFtool Flasher
#690 Post by Billycar11 » Sun Apr 09, 2023 6:32 pm
mike23 wrote: Sun Apr 09, 2023 6:26 pm Greetings all!
You didn't read the guide
Needs to be 2016+
You can recover select recover and follow the prompts and then flash your old fw not the backup the backup is useless pretty much
