quietvoid
#8056 Post by quietvoid » Wed Mar 08, 2023 3:17 am
RESET_9999 wrote:
Wed Mar 08, 2023 3:06 am
yes it is how it works... Each trims are edited manually after the analysis to make sure the desired look is preserved.
Dolby vision is not just an algorithm.
I'm only clarifying your statement that the trim passes are done two times (L8 + L2), because it's not true.
If you even did a little research, you would've found that L2 is always autogenerated.
So the trim passes are what creates the L8, not the L2. At least in a CM v4.0 workflow.
For CM v2.9, of course the trims are done once and they result in the L2.
As I told you in PM, take the spears and munsil, generate cmv4.0 metadata and compare on cmv2.9 and 4.0 devices. I'm sure you will agree.
That's not at all the same situation. It would only be comparing different algorithms.
#8057 Post by RESET_9999 » Wed Mar 08, 2023 3:25 am
LOL I know very well that the dv analysis generates L2/L8 automatically, I literally asked you by pm how to overwrite them in my script because they have a too strong effect....
My point is that the trims are edited manually after the analysis. They are NOT just the result of an algorithm.
The metadata in L2 and L8 works quite differently as you know, so i disagree with you here.
If they do L2 and L8 trims they must go through each of them but then we learned that the studios can be very lazy so who knows how much work they really put in the trims.
huh? please do some tests and then come at me again :)
dom61
#8058 Post by dom61 » Wed Mar 08, 2023 6:54 am
RESET_9999 wrote:
Tue Mar 07, 2023 11:06 pm
dom61 wrote:
Tue Mar 07, 2023 11:03 pm
Thank you for the confirmation
I went ahead in the procedure and when I am processing the file "DV.xml", it is prompted to enter a value of enter a value of CANVAS_WIDTH
mediainfo is used to read and set the input resolution. So your path to mediainfo might not be right??
I solved it by downloading the correct version
After processing a movie with DaVinci, I performed the export of Dolby Vision metadata (DV.xml), following the tutorial on Youtube as reference.
I ask if it is possible to inject only Dolby Vision metadata (DV.xml)
to get Mediainfo similar to this.
Thank you very much
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
#8059 Post by RESET_9999 » Wed Mar 08, 2023 11:59 am
Thank you very much
No, you can only create single layer files. In order to create a P7 dual-layer file, you must have/create an enhancement layer (EL) which is currently not possible.
It might be possible to make a blank EL in the future though but i believe the BL has to be encoded a certain way also.
dom61
#8060 Post by dom61 » Wed Mar 08, 2023 4:04 pm
I finally managed to import DV metadata, ask for confirmation if the procedure is correct.
I performed the procedure only for Dolby Vision, launched DoVi_Scripts 1>1 Drag & Drop MKV file and DV.xml file
And only the ".hevc" file is generated. , then I enter the file in MKVToolNix to create the mkv file which has these characteristics.
The "RPU.bin" file is not generated as in the videotutorial
My PC Ryzen 7950X
#8061 Post by RESET_9999 » Wed Mar 08, 2023 4:48 pm
yes by default no rpu is exported.. you must edit line 35 set keep_rpu=NO
Also, you must have turned off the muxing(line 21) because the script is supposed to mux to MKV.
dom61
#8062 Post by dom61 » Wed Mar 08, 2023 4:52 pm
OK line 39 has been changed, but line 21 is active.
My PC Ryzen 7950X
sultanmehmet
#8063 Post by sultanmehmet » Wed Mar 08, 2023 6:00 pm
RESET_9999 wrote:
Tue Mar 07, 2023 2:22 am
sultanmehmet wrote:
Tue Mar 07, 2023 1:42 am
Can somebody confirm if I can just copy the 'raw' m2ts file to my HDD?
No, you'll get "fake" DV if you do that. You must remux to TS/M2TS or BDMV with the nightly tsmuxer.
It sounds like you're using the very old tsmuxer. I use this version (had issues with the latest ones)...
https://github.com/justdan96/tsMuxer/re ... 2-02-15-09
Thanks man, that did the trick! I don't know how I didn't download that version as I thought I just went on google a couple of days ago and downloaded the lastest one. But it worked and I got my x700 in the mail today and tested it out. It played in hdr10 at first but I noticed that DV was turned off in the settings, so after I turned it on it worked like a charm! Its funny how even though this x700 feels like a cheap piece of plastic it plays back DV so effortlessly.
caelar900
#8064 Post by caelar900 » Wed Mar 08, 2023 9:35 pm
Finally got the script working and started converting most of my duplicate p5 files to p8 only to realize about 60 odd films in that p8 has the red push issue on shield -_- Looks like Apple TV with infuse doesn't work quite right either from some of the test patterns I was looking at. Oh well guess I'll be sticking with P5 for plex files and x800 for all my p7's.
Draco1544
#8065 Post by Draco1544 » Fri Mar 10, 2023 9:01 pm
@RESET_9999 Hi, where I can fine the DoVi_mp4_DVH1.exe required by your script for mp4 workflow ?
#8066 Post by RESET_9999 » Fri Mar 10, 2023 10:32 pm
here: https://github.com/rixtox/mp4dovi/releases/tag/v0.1.1
sorry, I should stop renaming the tools I'm using...
this is only needed when you use 7-1-1 and input a Profile 5 video. Some movies anywhere profile 5 web-dl produce corrupted video in mp4box.
BTW, latest beta can make MP4 with 7.1 EC3 audio. It can also now mux up to 40 subtitles and 10 audio.
ATV Infuse should work as long as your P8/P5 mp4 file is HEV1 / DVH1.
LV8HD
#8067 Post by LV8HD » Sat Mar 11, 2023 2:21 pm
Hi y'all, this doesn't necessary fit in the "Dolby Vision world", but I think it's quite interesting and inherent to this forum.
let's say I have 2 sources for the same movie -> 1st source US UHD Blu-ray
2nd source ITA UHD Blu-ray
The US UHD Blu-ray video is better than ITA, but US UHD has some hardsubs scenes that I don't like, while ITA UHD doesn't have any. What I would like to do in this case would be to extract the specific frames (corresponding to the one on the US
UHD containing hardsubs) from the ITA UHD and replace part of the US video with these non-hardsubbed scenes.
But before doing that I'd have to let's say "change" the ITA UHD frames HDR metadata to fit the US UHD ones.
How is it possible to do all of that? the first tools that come to my mind are of course MadVR and ffmpeg but I don't practically know how use them for this. Is there anybody who has any idea?
EDIT: forgot to mention I absolutely don't want to re-encode the video in any way.
jorgen
#8068 Post by jorgen » Sat Mar 11, 2023 3:55 pm
Is it possible to convert a UHD movie to mkv using makemkv and then reversing the process using TSMuxer to create a new BDMV without losing any Dolby Vision information? (I understand that Bluray menues will be removed etc., but I'm interested in knowing if a ripped mkv with DV is future proof and can be converted back to BDMV lossless). Thanks!
quietvoid
#8069 Post by quietvoid » Sun Mar 12, 2023 3:46 pm
There's a bug in MakeMKV when ripping from TSMuxer BDMV: viewtopic.php?f=12&t=23962&p=122050&hil ... er#p122050
So unless that is fixed, you would have a hard time ripping again.
It's probably better to archive the original disc backup instead.
jorgen
#8070 Post by jorgen » Wed Mar 15, 2023 6:25 pm
I'm not interested in converting from back from BDMV with TSMuxer to mkv.
The process I'm interested in is this:
- Rip retail UHD disc to mkv and store on NAS
- Keep mkv file on NAS
- Create temporary BDMV structure with TSMuxer from mkv to watch movie on Oppo player (with best DV support)
- Delete BDMV files
Question is if keeping a mkv backup is future proof. The bug I understand is converting the other way, from BDMV structure with TSMuxer to mkv again?
Thanks in advance.
