LG BP60NB10: Sleep Bug Issue?
trevork99
#1 Post by trevork99 » Wed Mar 08, 2023 1:10 am
I purchased the LG BP60NB10 slim drive as a result of my ASUS BC-12B1ST failing to rip several specific UHD discs. This new drive is able to read and rip most of those discs without issues, but sometimes I run into a strange issue where the drive will sometimes quit ripping and MakeMKV starts throwing device errors. Here's one of the attempts I made ripping my copy of Star Wars: A New Hope:
MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
File 00004.mpls was added as title #0
File 00802.mpls was added as title #1
File 00803.mpls was added as title #2
File 00020.mpls was added as title #3
File 00801.mpls was added as title #4
File 00800.mpls was added as title #5
Title 00004.mpls is equal to title 00800.mpls and was skipped
Saving 1 titles into directory G:/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00066.m2ts' at offset '31179276288'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '31179276288'
Failed to save title 4 to file G://Star Wars- A New Hope_t04.mkv
Encountered 38 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
It was working fine up to 99%, then the drive randomly went to sleep for a second and started making irritating sounds (sounds like the sleep bug). I have not had this issue with my ASUS drive, and I flashed the LG with the correct matching MK firmware (1.02MK; the drive came with 1.02 firmware), so I'm a little confused as to why this would be happening. Ripping the same disc with my ASUS drive throws "INVALID FIELD" errors instead, and fails at around the 30% mark or so.
So is this the result of an actual bad disc, or is there something on my new drive that I need to double check?
Re: LG BP60NB10: Sleep Bug Issue?
#2 Post by Billycar11 » Wed Mar 08, 2023 1:22 am
no not the sleepbug i think its just a bad disc or disc that needs to be cleaned.
any official or or drive flashed to official UHD firmware does not have the sleep bug
trevork99
#3 Post by trevork99 » Wed Mar 08, 2023 1:38 am
Billycar11 wrote: Wed Mar 08, 2023 1:22 am no not the sleepbug i think its just a bad disc or disc that needs to be cleaned.
I may have to clean the disc again then. I had a feeling it wasn't the sleep bug, but I wasn't sure. I will say this drive does read discs better than the ASUS drive so far.
trevork99
#4 Post by trevork99 » Wed Mar 08, 2023 2:13 am
I cleaned the disc, and now I'm suddenly getting completely different errors.
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '11735138304'
Error 'OS error - {Verifying Disk} The media has changed and a verify operation is in progress so no reads or writes may be performed to the device, except those used in the verify operation' occurred while reading '\Device\CdRom1' at offset '11735138304'
Error 'OS error - A device which does not exist was specified' occurred while reading '\Device\CdRom1' at offset '11735138304'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '11735138304'
Encountered 2 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Now it's failing at 23%.
#5 Post by Billycar11 » Wed Mar 08, 2023 4:52 am
this is usually a power error NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY
use both cables direct into the motherboard or get a high powered usb hub like this https://www.amazon.com/gp/product/B0797 ... R7PE&psc=1
trevork99
#6 Post by trevork99 » Fri Mar 10, 2023 1:51 pm
Billycar11 wrote: Wed Mar 08, 2023 4:52 am this is usually a power error NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY
I was using my desktop computer's front USB ports so maybe plugging the cables back there may work. If not, I'll look into a powered hub. I thought only laptops ran into this issue but I suppose not.
EDIT: Still failing at 99%, same errors as in the original post. I blame this disc being straight-up bad. Looks like I'll have to obtain a replacement. Oh well.
