Folder access for the Mac
cazzie98
Post by cazzie98 » Tue Mar 07, 2023 7:37 pm
Every time I create a file it need permission from mac to add the file to a folder. Is there a way to give MakeMKV permission so I dont have to give it permission every time?
Re: Folder access for the Mac
Post by Woodstock » Tue Mar 07, 2023 7:58 pm
Sounds like the folder has permissions set to "ask" for write ability, which is separate from MakeMKV permissions.
Does it do it for ALL folders, or just certain ones?
Post by dcoke22 » Tue Mar 07, 2023 9:54 pm
You probably need to grant Full Disk Access to MakeMKV in the Security & Privacy pane in System Preferences.
Some additional links about full disk access.
macOS Mojave: For app permissions, what’s the difference between Accessibility and Full Disk Access?
MANUALLY GRANTING APPLICATIONS FULL DISK ACCESS IN MACOS CATALINA
8u5jl
Post by 8u5jl » Tue Mar 28, 2023 7:25 pm
I have granted Full Disk Access both to the MakeMKV.app and to the binary `/Applications/MakeMKV.app/Contents/MacOS/makemkv`, but it doesn't help, I keep getting this prompt, seemingly every time MakeMKV starts writing a new file:
"“makemkv” would like to access files on a removable volume."
I am writing the backup to an external drive, this is on macOS 13.3.
If I write the backup to the internal drive, I only get the prompt twice, that's it.
royale
Post by royale » Thu Mar 30, 2023 2:53 pm
In Finder, if I right-click MakeMKV, "Show Package Contents", and add the "MacOS/makemkv" executable binary, that resolves it for me. Assuming you've restarted the app, I don't understanding why you're still getting prompted. It's still happening across restarts? If you've updated MakeMKV, you might need to re-add the `makemkv` binary.
