sultanmehmet wrote:
Mon Mar 06, 2023 3:36 pm
What does 'forced subtitles' mean? I didn't get this part.
Forced Subtitles are subtitles that display even when you have subtitles turned off. A classic example is Sean Connery speaking Russian at the beginning of The Hunt for Red October (1990).
sultanmehmet
Post by sultanmehmet »
dcoke22 wrote:
Mon Mar 06, 2023 6:38 pm
Is this the same as 'hardsubs' aka 'baked in' subs?
jayper
Post by jayper »
sultanmehmet wrote:
Mon Mar 06, 2023 8:57 pm
It is different, because they are not 'baked into' the video. They are generated during playback by the player.
sultanmehmet
I understand. I am now muxing them with Tsmuxer in anticipation for my x700 to arrive probably in 2 days. I muxed 1 with succes but got a “Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps.” error during the second one.
This doesn't matter wheather I do TS muxing or M2TS muxing. It happens every time at 13.9%. I don't really know where to go from here. I thought it was perhaps audio related but it's the only English audio track on the Blu-Ray so I don't really have a choice.
My input file was the m2ts file (90GB) if that's important at all.
EDIT: I also read on the spreadsheet that you can also use m2ts files. In this case, can I just drag on drop the m2ts file unto the HDD? Every audio and subtitle track that I want to use is the default one (english & english). And they are m2ts so there is no TrueHD core to not be present.
sultanmehmet wrote:
Mon Mar 06, 2023 10:27 pm
Use the mpls (playlist) file for the movie as the input, not the m2ts file.
sultanmehmet
Thanks for the suggestion. I had also tried that and that also failed, at the exact same place. Then I tried another movie and that one also failed with the same error but at 32%. Worst thing is I don't even understand the error very much so I don't know how to solve it. Tried Googling it but people seem to be getting this error since 2009 so I could be all sorts of things.
Can somebody confirm if I can just copy the 'raw' m2ts file to my HDD? Or does that also need to be muxed beforehands to a muxed m2ts?
sultanmehmet wrote:
Tue Mar 07, 2023 1:42 am
No, you'll get "fake" DV if you do that. You must remux to TS/M2TS or BDMV with the nightly tsmuxer.
It sounds like you're using the very old tsmuxer. I use this version (had issues with the latest ones)...
https://github.com/justdan96/tsMuxer/re ... 2-02-15-09
dom61
Post by dom61 »
Good morning.
I followed the Generate Dolby Vision and HDR10plus videotutorial in Davinci Resolve.
https://www.youtube.com/watch?v=ZdFiqATo_j8&t=325s
I generated the two files "DV.xml" and "HDR10plus.json", launched "DoVi_Script 1.7.0" Choice 6>5, dragged the video file (mkv) and after that the file "HDR10plus.json".
I get the message "Unable to find the specified path".
I have done the procedure several times, but I can't figure out
where I'm going wrong.
Thank you very much
Translated with www.DeepL.com/Translator (free version)
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
dom61 wrote:
Tue Mar 07, 2023 8:08 am
Good morning.
Looks like you didnt download and set the tools path: https://drive.google.com/drive/u/1/fold ... J2M9DvOQRu
You should also update to 1.7.6 in which you can now use (1-1) to inject both XML and json.
jayper
Post by jayper »
RESET_9999 wrote:
Tue Mar 07, 2023 12:04 pm
Is 1.7.6 official now? Or still in beta? Thanks again for all of your effort on this project.
jayper wrote:
Tue Mar 07, 2023 6:28 pm
yes it's the latest stable version but a new beta 1.7.6.1 coming up later today.
-- HDR10plus_tool and Dovi_tool must be updated to the latest version (hdr10plus to DV was totally wrong with the old dovi_tool)
I suggest you re-do any HDR10plus to DV conversion you did with the old dovi_tool
see: https://slow.pics/c/G6OH6k9p
-- HDR10plus plotter no longer requires python
-- new workflow that can batch remove CMV4.0 metadata block (2-1-6):
most of the CMV4.0 movies only have a L8 100nits trims and L2 has no effect on CMV4.0 device(shield,firestick,tv internal)
pattern to see what I'm talking about:
CMV4.0 original: https://drive.google.com/file/d/1lR1u9H ... share_link
cmv4.0 removed: https://drive.google.com/file/d/1ZqS9Ml ... share_link
-- bugfix: (2-1-5) batch edit L5 failed after the first file for mkv input
-- Code cleanup
caelar900
Post by caelar900 »
RESET_9999 wrote:
Fri Feb 24, 2023 8:19 pm
dom61 wrote:
Fri Feb 24, 2023 7:47 pm
I have exported HDR 10+ and Dolby Vison metadata via DaVinci Resolve.
you can use the script in my signature (workflow 1-1) to inject both metadata. Or use the Dovi_tool and HDR10plus_tool to inject manually, you can find these tools on quietvoid's GitHub.
Dinst wrote:
Thu Feb 16, 2023 6:24 pm
Has anybody got a link to a decent tutorial for generating Dolby Vision using Davinci Resolve?
see my youtube channel (link in my signature), i made a video tutorial a while ago.
if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected :)
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWA
Looks like mega took this folder down. Anyway you could reupload?
caelar900 wrote:
Tue Mar 07, 2023 7:05 pm
yeah i should have mentioned that the link would be online for only 1 week.
I PMed you a new link.
jayper
Post by jayper »
RESET_9999 wrote:
Tue Mar 07, 2023 6:53 pm
-- Code cleanup
Thanks so much! Apologies, but I am not yet well-read on the CMV4.0 vs CMV2.9 discussion. Is there a reason one would prefer one versus the other? I'm guessing it is more future-proof, but at this time most hardware doesn't support it? Is there a downside to keeping it?
dom61
Post by dom61 »
Good evening.
I apologize using the link Read Me https://github.com/quietvoid/hdr10plus_tool
I can download "hdr10plus_tool.exe" and not "hdr10plus_parser.exe"
Should I rename the file?
Thank you
My PC Ryzen 7950X
