MakeMKV Trojans
LIONELMESSI
MakeMKV Trojans
Post by LIONELMESSI »
I was analyzing the MakeMKV executable in VirusTotal, the file was downloaded from this same website and VirusTotal tells me that the file is infected with 2 trojans
Can someone tell me if it's true?
Re: MakeMKV Trojans
false positive
Re: MakeMKV Trojans
Again?
Seems like someone likes to list it every couple of months, and usually for the same thing (an install file for 32-bit).
Same advice as usual - submit a copy of the download to them to have them notice that they screwed up again. Or trust your chosen antivirus product's opinion.
Edited to add: Just submitted the URL for the MSDOS file, and VirusTotal currrently says, "No security vendors flagged this URL as malicious". I wonder how long that will last?
Re: MakeMKV Trojans
Post by d00zah »
LIONELMESSI wrote:
Mon Mar 06, 2023 1:07 am
False positives happen all the time. 65 vendors out of 68 say it's safe, but people always seem to focus on the outliers? If you use one of them, file a report & get them to reassess & explain.
BitDefender had a problem w/ v1.17.2 & the MakeMKV author provided comments:
viewtopic.php?f=1&t=30174
