Pioneer BDR-XS07TUHD & Firmware 1.02
Konten
Post by Konten »
My current Pioneer BDR-XS07TUHD came with FW 1.01 and worked great with LibreDrive on my Mac.
Unfortunately, it 'experienced' water damage (don't ask... :( ) and needed replacing...
The new one is on its way but I believe will come with Firmware 1.02 which apparently was released on December 21, 2022. As I bought it from Germany, I am assuming it's the BDR-XS07UHD_TUHD_V102EU version listed on the Pioneer website.
Would anyone know, will this still be compatible with LibreDrive or does that FW have the same issue mentioned here: viewtopic.php?f=19&t=30383?
Thanks, guys!!
Re: Pioneer BDR-XS07TUHD & Firmware 1.02
same issue as the post you linked eta on a fix is a few weeks likely will need to be flashed
the days of pioneers not needing to be flashed are probably over
Konten
Post by Konten »
Thank you, Billy! That's a shame... :-(
I will need to wait for a fix hopefully becoming available then.
This only affects UHD discs though, right? Blu-ray and DVDs should still be ok?
Konten wrote: Sun Mar 05, 2023 9:51 am Thank you, Billy! That's a shame... :-(
yes uhd only
Konten
Post by Konten »
Thank you!! :-)
