Persistent artifacts showing up in Blu-Ray rip
omegaman3966
#1 Post by omegaman3966 » Sat Mar 04, 2023 9:51 am
I was attempting to rip a copy of John Wick 2 and came across the playlist obfuscation issue where I was able to locate the correct segment map through the forums, but still ended up with alot of artifacts on the file? I even verified the main file name using AnyDVD (which was the same one from the forums, 00440.mpls) and attempted another rip using a trial version of CloneBD instead and there were no issues with playback. I've cleaned the disk and restarted my pc and the issue still persists when I try using MakeMKV. I don't wanna fork out money for extra software that I don't need so what gives?
Re: Persistent artifacts showing up in Blu-Ray rip
#2 Post by dcoke22 » Sat Mar 04, 2023 4:18 pm
Can you be more specific about what 'artifacts on the file' means?
Did MakeMKV have any errors or other messages in the log while you were doing the rip? Can you post it here?
omegaman3966
#3 Post by omegaman3966 » Sat Mar 04, 2023 10:01 pm
I think the problem has gone away for now. There were these green horizontal rectangles which appeared when I scrub the through the timeline on VLC, but if I let the file play out nothing seems to appear.
drxenos
#4 Post by drxenos » Sun Mar 05, 2023 3:51 pm
VLC is notorious for that when hardware acceleration is turned on.
