unable to backup or convert Quantum of Solace or The Mummy
corvin
#1 Post by corvin » Thu May 12, 2011 10:48 pm
Blu-ray disks, any ideas?
crowfax
Re: unable to backup or convert Quantum of Solace or The Mum
#2 Post by crowfax » Fri May 13, 2011 2:15 am
Turn on debugging and post your log please.
corvin
#3 Post by corvin » Fri May 13, 2011 7:12 am
Quantum of Solace
Saving 1 titles into directory /Volumes/WDTVLiveHub/Blu-ray Movies/Quantum of Solace
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '3527933952'
DEBUG: Code 0 at jWCy\ONV2n$<4ei25=qu:29394298
DEBUG: Code 0 at 4Z!hn3Gh47CjT/:A9c6+:121261681
DEBUG: Code 0 at jWCy\ONV2n$<4ei25=qu:29394183
DEBUG: Code 1722624 at jWCy\ONV2n$<4ei25=qu:29393309
DEBUG: Code 0 at XRLYf,-i/GR' Z ^\@F6J:29397472
Failed to save title 0 to file /Volumes/WDTVLiveHub/Blu-ray Movies/Quantum of Solace/title00.mkv
0 titles saved, 1 failed
crowfax
#4 Post by crowfax » Fri May 13, 2011 2:44 pm
corvin wrote:Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '3527933952'
Damaged/defective disc or failing drive.
Sorry.
corvin
#5 Post by corvin » Sat May 14, 2011 11:48 pm
Strange,
I am going through my collection and these 2 movies are the only ones that have caused a problem so far of about 200 bLu-ray movies. So i guess it rules out the drive and both look and function fine so that would rule out the disks?
Icetrips
#6 Post by Icetrips » Fri Jun 03, 2011 4:02 pm
Try to clean the disk with water.
This could fix your issue.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
crowfax
#7 Post by crowfax » Fri Jun 03, 2011 4:22 pm
corvin wrote:So i guess it rules out the drive and both look and function fine so that would rule out the disks?
Do not confuse playing and ripping discs. Just because it "looks fine" and plays ok does not mean it will rip. A player will skip over any bad sectors on the disc and you may not even notice. When you rip the disc you're performing a bit-for-bit copy of the movie, the option of simply skipping the bad sectors isn't there.
