LibreDrive BU40N unable to decrypt UHD disks
Housatonic
Post by Housatonic » Sat Nov 05, 2022 3:12 am
I have a fully patched BU40N drive that rips all DVDs and Blurays. It can see the UHD disks and titles but always fails with an AACS error of failure to decrypt.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.04
Serial number: MO1K43D4058
Firmware date: 2120-05-06 11:42
Highest AACS version: 76
Firmware version: 1.04
Disc Information
Label: INDEPENDENCE_DAY
Timestamp: 2016-03-30 13:09:31
Data capacity: 59.23 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.16.3 linux(x64-release) started
Using LibreDrive mode (v06.2 id=FA108BB7DA63)
Saved AACS dump file as /home/will/Videos/MKB20_v60_Independence_Day_0C81.tgz
This error is on all my UHD disks. It is a UHD drive, so what do I need to do, if anything?
Thanks in advance.
Re: LibreDrive BU40N unable to decrypt UHD drives
Post by MartyMcNuts » Sat Nov 05, 2022 5:14 am
Housatonic wrote: Sat Nov 05, 2022 3:12 am I have a fully patched BU40N drive that rips all DVDs and Blurays. It can see the UHD disks and titles but always fails with an AACS error of failure to decrypt.
Revision: 1.04
Disc Information
Number of layers: 2
Thanks in advance.
Ensure that MakeMKV has internat acces enabled in preferences so that the UHD volume keys can be downloaded. You are also using an old MakeMKV version. Might need to check for an update.
Housatonic
Re: LibreDrive BU40N unable to decrypt UHD disks
Post by Housatonic » Sat Nov 05, 2022 7:03 am
I have the internet access enabled, so that is not the problem. This version is the latest flatpak version. I am so not interested in compiling from source because I always break my system when I go rogue with that avenue. I will check the Win10 latest version. I do believe my installed version is not the problem. I can not rip any UHD, even older ones that predate my version by many years. This very disk listed, Independence Day, is from 2016 and my Makemkv version is from earlier this year. Should I upload this AACS dump file it saved? Would that help solve the problem?
Housatonic
Post by Housatonic » Sat Nov 05, 2022 7:27 am
Is there any way to download UHD volume keys and integrate with MakeMKV? I see in the forum a spreadsheet of all known UHD disks. Couldn't these be integrated with the SDF file that MakeMKV downloads when it first opens?
:) will
Housatonic
Post by Housatonic » Sat Nov 05, 2022 8:16 am
Hi MartyMcNuts,
I booted my ancient Win10 OS and it works. I guess the thugs of Linus need to up their game.
Thanks,
Will
Title #00632.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00633.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Independence Day
Bordwalk2000
Post by Bordwalk2000 » Thu Mar 02, 2023 8:12 pm
I am also having this same problem. It will work on a Windows Machine but it doesn't work on Linux.
Post by Billycar11 » Thu Mar 02, 2023 9:38 pm
Bordwalk2000 wrote: Thu Mar 02, 2023 8:12 pm I am also having this same problem. It will work on a Windows Machine but it doesn't work on Linux.
Flash to 1.00 BU40N in the de pack and see if it works on both
Joyfully3608
Post by Joyfully3608 » Tue May 02, 2023 7:49 pm
Billycar11 wrote: Thu Mar 02, 2023 9:38 pm Flash to 1.00 BU40N in the de pack and see if it works on both
I had the same issue, works on Windows 11 but not on Linux (unRaid). Flashed to 1.00 and now it works. Is there any disadvantage to using the older firmware version or is it irrelevant and I can just continue using it without a problem?
Post by Billycar11 » Wed May 03, 2023 8:20 am
Joyfully3608 wrote: Tue May 02, 2023 7:49 pm
irrelevant
