Errors ripping UHD discs
AndyMac
Post by AndyMac »
I have a WH16NS60 drive that is supposed to be able to read UHD discs according to the guide in these forums. It seem the disc fine and attempts to rip the files but I get errors like these until the rip eventually fails. Most 4K discs fail in this same way but I have been able to rip a few. After the Puss in Boots failure this morning I had no problems ripping SpiderMan-No Way Home.
When I click the link in the error (http://www.makemkv.com/errors/hashcheck/) it indicates I might have a failing drive. Is that correct or is there something else I need to do? I don't have any issues rippping regular BluRays. Could it be a firmware issue on the drive?
Rip Output --------------------------------------------------------
MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
Using Java runtime from C:\Program Files\Java\jre1.8.0_281\bin\java.exe
Title #00156.mpls has length of 61 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00157.mpls has length of 60 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00600.mpls has length of 24 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
< A bunch of skipped files for length>
Title #00511.m2ts has length of 868 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00512.m2ts has length of 7 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00513.m2ts has length of 7 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Saving 1 titles into directory D:/Disc Rips
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 2336821248, attempting to work around
Hash check failed for file 00294.m2ts at offset 2336876544, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 2354688000, attempting to work around
Hash check failed for file 00294.m2ts at offset 2354767872, file is corrupt.
<And so on until...>
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 2405627904, attempting to work around
Failed to save title 0 to file D:/Disc Rips/Puss in Boots- The Last Wish_00801-SEG_MainFeature.mkv
Encountered 6 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Here is the drive/firmware information. -----------------------------------------
OS device name: A:
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: SIK9MH8SB313
Firmware date: 2117-04-25 17:56
Highest AACS version: 78
Firmware version: 1.00
Disc Information
Label: PUSS_IN_BOOTS_THE_LAST_WISH
Timestamp: 2022-12-22 15:37:43
Protection: AACS2.0/C v77
Data capacity: 61.66 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Re: Errors ripping UHD discs
Clean the disc with liquid soap and warm water. Dry with a microfiber cloth as used cleaning glasses. Try again. I suggest to rip to folder.
