Convert backup to ISO
Re: Convert backup to ISO
Post by d00zah » Thu Mar 02, 2023 3:11 pm
Being unfamiliar w/ Zidoo in general, I did a quick search. My impression is that ISO playback seems to be hit, or miss, depending on release, Zidoo player model/FW version & less dependent on processing. There's certainly a lot of discussion available on the subject. I would suggest more research along those lines. YMMV
wesg92
Post by wesg92 » Thu Mar 02, 2023 3:13 pm
Thanks, I just didn't know if I should try changing any of these settings, like UDF 2.6 maybe?
Data Type: MODE1/2048
File System: UDF
UDF Revision: 2.50
Post by d00zah » Thu Mar 02, 2023 4:06 pm
wesg92 wrote: Thu Mar 02, 2023 3:13 pm Thanks, I just didn't know if I should try changing any of these settings, like UDF 2.6 maybe?
File System: UDF
UDF Revision: 2.50
Without knowing the specific player model #, FW version, etc. (missed it, if mentioned earlier) to determine format details, you might want to poke around Zidoo forums, or Support before further investigation. Considering the results of my last search, I would start by determining Zidoos specific requirements & then apply that to determining how to get there. Make sense?
wesg92
Post by wesg92 » Thu Mar 02, 2023 5:30 pm
Hi, yes, good call. I posted on the Zidoo forums as well. Thx!
Post by d00zah » Thu Mar 02, 2023 5:43 pm
wesg92 wrote: Thu Mar 02, 2023 5:30 pm Hi, yes, good call. I posted on the Zidoo forums as well. Thx!
Happy hunting! :D
Post by Billycar11 » Thu Mar 02, 2023 9:42 pm
wesg92 wrote: Thu Mar 02, 2023 2:47 pm Update:
I created a decrypted back of the disc in MakeMKV.
I sent the backup folder to a friend via dropbox.
He used ImgBurn to create an ISO with these settings:
File System: UDF
UDF Revision: 2.50
When I play the ISO on the Zidoo, it says "Can't play video"
What should I try next?
Does it just work with the decrypted folder directly from makemkv it the same as iso basically but it's a folder
Post by dcoke22 » Thu Mar 02, 2023 9:48 pm
Billycar11 wrote: Thu Mar 02, 2023 9:42 pm Does it just work with the decrypted folder directly from makemkv it the same as iso basically but it's a folder
The OP tried, but it didn't work. viewtopic.php?p=132321#p132321
neo305
Post by neo305 » Sun Nov 16, 2025 7:14 pm
Ok and for windows? How can we shrink it to 25GB?
Post by Coopervid » Sun Nov 16, 2025 8:22 pm
neo305 wrote: Sun Nov 16, 2025 7:14 pm Ok and for windows? How can we shrink it to 25GB?
The easiest way is CloneBD but for shrinking it's payware.
